Can someone list the necessary tools to pull a motor? please
going to be pulling my motor soon and just wanted to make sure i had everything i would need, if you dont mind could someone type up a short list of what ill need, thank you for your time
im gonna forget **** but here
a Helms
socket set (8,10,12,14,17)
deep sockets (8,10,12,14,17)
wrenches (8,10,12,14,17)
breaker bar (big one)
32mm axle socket
engine lift.
chain
hooks
channel locks
pliers
vice grips
screwdrivers (both)
needle nose
8mm non tapered punch (shift linkage pin)
torque wrench
thats about all i can think of.
a Helms
32mm axle socket
engine lift.
chain
hooks
channel locks
pliers
vice grips
screwdrivers (both)
needle nose
torque wrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 »</TD></TR><TR><TD CLASS="quote">Dont have to have but a ball joint seperator is nice to have. If you dont have one you can rent one at autozone</TD></TR></TABLE>
you dont even need to seperate the ball joints, just remove the bolt for the strut wishbone and the 2 for the suspension where the LCA meets the frame, it will pull down and away.
Deo
10
Jul 19, 2005 04:38 PM
fasterthanU
Jan 10, 2004 10:19 AM
