Can I use these?
Old Mar 12, 2004 | 09:21 AM
85mm LS VTEC's Avatar
Default Can I use these?
Arp Acura main studs part # 208-5403, will these be compatable with my LS. Is the thread and length the same as a OEM LS main stud?
Old Mar 12, 2004 | 10:03 AM
dfoxengr's Avatar
Default Re: Can I use these? (85mm LS VTEC)
if theyre made for the LS then yes theyre the same. if not theyre for a GSR most likely and wont work becasue of the girdle needing longer bolts.
Old Mar 12, 2004 | 11:14 AM
RedlinedVTEC's Avatar
The 208-5403 are a B18C1 part number, so no they will not work with your LS block.
Old Mar 12, 2004 | 03:17 PM
Default Re: Can I use these? (RedlinedVTEC)
So does anyone make aftermarket main bolts for an LS block or am I going to have to use OEM?
lickety_britches
Nov 15, 2008 06:51 PM
bbbleondacomeup
Apr 18, 2007 02:59 PM
[Ennis_D]
May 17, 2006 04:32 PM
Blackack26
Sep 1, 2005 07:51 AM
