Can I swap out cranks?
Old Oct 3, 2001 | 11:49 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Can I swap out cranks?
Can I swap a B18C crank and put it into a B16 to make it 1.8L? I know the bore is the same, but the difference would be the stroke. Now I would also use B18c rods and pistons so the only thing I would use is the B16 casing?
art
Old Oct 4, 2001 | 05:08 AM
rainforest's Avatar
Default Re: Can I swap out cranks? (Arturbo)
1.b16a's stroke is 77 b18c's is 87
2.b16a's rods are 134mm b18c are 137
3.b16a's decks are 263mm b18c's are 270
To tell you the truth i have never seen this done. But i don't think it would be a good idea in theroy. Thre might be issues with some valve tapping. Not really sure I have never done it or seen it happen. Just get a ls/gsr bottom end.
Old Oct 4, 2001 | 05:31 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Can I swap out cranks? (rainforest)
That was good info and that was what i was looking for. Thanks!
janiscrulzz
70
Dec 11, 2011 04:49 PM
061000rr
Sep 24, 2009 02:08 AM
bsmith100
Jun 5, 2009 01:07 PM
mrEM1
Sep 7, 2005 03:41 PM
ekekek
Feb 7, 2002 10:00 AM
