Can ECU's be repaired???
Old Jun 30, 2003 | 11:02 AM
crxtreme27's Avatar
Default Can ECU's be repaired???
Yesterday i decided to try out my PW0 ecu that i was saving for my other swap... When i turned on the car, i got a check engine light right away and it gave me a code 4, crank angle sensor i think, and the car would not idle at all, it was about to turn off. Then i put back my PR3 ecu and everything was back to normal with no check engine light. This means i have a faulty ECU right?? Is there a way i can fix that so that i can reuse the ECU?? Please give me some info on this...
Thanks
Old Jun 30, 2003 | 12:29 PM
martini's Avatar
Default Re: Can ECU's be repaired??? (crxtreme27)
is your PW0 for an auto?
Old Jul 1, 2003 | 10:53 AM
crxtreme27's Avatar
Default Re: Can ECU's be repaired??? (martini)
From what i was told it was a 5 speed, I think that if it was for an auto it would give me a different code, it happened to me before....
schillshak
Feb 1, 2010 11:14 AM
Chris_Bye
Jul 10, 2004 12:10 PM
crxtreme27
Jul 1, 2003 04:30 PM
Xbuilt2lastX
Oct 15, 2001 10:55 AM
