Cams won't turn over, HELP
Old Sep 6, 2005 | 07:27 PM
krazie1's Avatar
BANNED
Default Cams won't turn over, HELP
well here is the problem. I have installed my old b16a ported OBD0 head with RM valvetrain, oversized valves. Removed the LS/vtec plug and tap. using Omniman LMA's and freahly given a 3 angle valve job and resurfaced. Bolted to a sir2 block I had and purchased a buddy club headgasket(.4mm) and BC 3+ cams. Now if I manually turn it the belt skips . I tried it without the plugs or timing belt and it still don't turn. Won't try to go in case I am hitting the valves to the pistons u know.
So with all that said, what u guys think it could be. I did swap cam caps(as I thought thew obd1 were better looking ) Still ain't it....
Old Sep 6, 2005 | 09:26 PM
rev-speed's Avatar
so can u turn the engine over
by hand?
with the belt off or on?
plugs off or on
Old Sep 7, 2005 | 12:01 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Cams won't turn over, HELP (krazie1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">well here is the problem. I have installed my old b16a ported OBD0 head with RM valvetrain, oversized valves. Removed the LS/vtec plug and tap. using Omniman LMA's and freahly given a 3 angle valve job and resurfaced. Bolted to a sir2 block I had and purchased a buddy club headgasket(.4mm) and BC 3+ cams. Now if I manually turn it the belt skips . I tried it without the plugs or timing belt and it still don't turn. Won't try to go in case I am hitting the valves to the pistons u know.
I hope you lubed the cams very well and tensioned the belt properly. I hope you mean that you changed oiling rails, and not the cam caps from and obd1 motor
Old Sep 7, 2005 | 12:48 AM
gsrious's Avatar
i think you should just try to loosen the valve adjustments...
**this one time when we were putting in cower stage 2 cam... we forgot to loosen the valve adjustments(lash). it was so hard to turnover at all(wouldn't even budge). almost strip the cam gear bolt from the cam shaft trying to turn over the cams with a big rachet.
Old Sep 7, 2005 | 02:04 PM
krazie1's Avatar
BANNED
Default Re: (gsrious)
ok ok will try that but it was set to stock valve lash before hand but will try it
hopefully this is it
any more ideas
Old Sep 7, 2005 | 06:33 PM
ekgcool's Avatar
Default Re: (krazie1)
I had the same problem. I forgot to lube the cams, journals, caps, and vlavetrain. Everything was dry as hell and the cams didnt want to move.
Old Sep 7, 2005 | 08:05 PM
krazie1's Avatar
BANNED
Default Re: (tekracer)
found out what it was, stupid me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">i think you should just try to loosen the valve adjustments...
**this one time when we were putting in cower stage 2 cam... we forgot to loosen the valve adjustments(lash). it was so hard to turnover at all(wouldn't even budge). almost strip the cam gear bolt from the cam shaft trying to turn over the cams with a big rachet.</TD></TR></TABLE>[QUOTE=gsrious]i think you should just try to loosen the valve adjustments...
thanks a bunch guys
webster426
Jul 12, 2009 04:35 PM
01-DC2R
12
Sep 12, 2007 03:08 PM
DelSol-B-18
Jun 5, 2005 04:28 PM
cRxAuDio
Sep 10, 2003 01:18 AM
