Which Cams are better, CTR or ITR?
Old Nov 8, 2002 | 11:20 AM
99YZF's Avatar
Default Which Cams are better, CTR or ITR?
I want to use one of the two, but don't know which ones are better. Going in a B16 head with headwork.
Old Nov 8, 2002 | 02:12 PM
10K2HVN's Avatar
Default Re: Which Cams are better, CTR or ITR? (sir2crx)
from what i heard, the new ITR cams and the CTR cams are the same - except for the early year ITR's (97) - something to do with less duration, on those models...
Old Nov 8, 2002 | 02:30 PM
qcoffey's Avatar
Default Re: Which Cams are better, CTR or ITR? (10K2HVN)
Go with a set of skunk2 stage 2, they are supposed to be real nice.
Old Nov 9, 2002 | 07:08 PM
infamousALLMTR's Avatar
Default Re: Which Cams are better, CTR or ITR? (qcoffey)
only prob is you have to run the whole skunk2 valvetrain... talking 1g +
Old Nov 9, 2002 | 08:59 PM
SpoonSportsJunkie's Avatar
As far as I have been shown and told, Ctr cams have 3degrees more duration.
While some rant and rave about how great the ctr cam is over an Itr ...others state that even with cam gear / dyno tuning. that a ctr cams maybe gives 1-2 hp more in certain rpm ranges.. Kinda Overated IMO (although I will be quick to state I havent driven a car w/ them yet) If you don't want to upgrade valvetrain... Toda spec A's ! or spec b's if you can get Itr intake outter valvesprings w/ portflow inners. And use your B16a Intake springs (inner/outer) on the exhaust portion of your motor.
Old Nov 10, 2002 | 01:27 AM
travis's Avatar
Default Re: Which Cams are better, CTR or ITR? (SpoonFanatic)
Yup, and if I remember correctly it's only on the VTEC lobe, and only on the intake side.
Old Nov 10, 2002 | 10:45 AM
boostinb18's Avatar
Default Re: Which Cams are better, CTR or ITR? (travis)
what are the gains on these toda's?? and price for them??? anyon running these cams?? do you like them??
Old Nov 10, 2002 | 12:39 PM
AzG35's Avatar
ALL R cams are the same on the exhaust side. CTR's and 00+ ITR's are slightly bigger than 98 and below only on the duration side. Like posted about, 3 degrees. The 00+ cams are questionable about how much bigger, some people say they are the same as CTR's, but they are definately bigger than the 97-98 spec R cams.
Old Nov 10, 2002 | 03:12 PM
Default Re: Which Cams are better, CTR or ITR? (boostinb18)
What are the gains on these toda's?? and price for them??? anyon running these cams?? do you like them??
On my friends 00' Integra type r, He ran Toda Racing spec B cams w/ gears, and apex-i VFAC, 4-1 Jdm Integra R header. He put down ~10-15 hp midrange and like ~ 20 in the high rpm range! I believe! all this was @ the wheels!!!!
You can find out more about these great cams at http://www.Randdmotorsports.com
Dave is a good businessman to deal with!
rico suave
May 27, 2012 09:32 PM
projekZERO
Aug 29, 2005 04:06 PM
BigAnold
Jul 1, 2005 06:33 PM
498GSR
Oct 28, 2002 10:06 PM
CLICC916
18
Nov 6, 2001 05:36 AM
