Camber Woes FROM HELL!!!!!!
Old Mar 28, 2003 | 03:34 PM
ill_take_one's Avatar
Default Camber Woes FROM HELL!!!!!!
Ok, i really do have bad camber, and maybe its my "toe in" thats mainly screwed.
ANyway, i received an Ingalls front kit from a guy on this board. Now, I'm not sure what should be included, but i SWEAR i got TWO kits???
God i hope i'm right... no flamage please!
Also, any links as to how to install these bad boys (fronts)?
Thanks
[edit] i'm a dumb ***..[edit]
Please at least give me instructions on how to install these
THanks
[Modified by ill_take_one, 12:39 AM 3/29/2003]
Old Mar 28, 2003 | 04:05 PM
poison's Avatar
Default Re: Camber Woes FROM HELL!!!!!! (ill_take_one)
It should include instructions, but there are different type of Camber kits.
Unfortunately, I don't know installation of the Ingalls. What type of front camber kit is it?
Old Mar 28, 2003 | 04:25 PM
Shift!'s Avatar
Default Re: Camber Woes FROM HELL!!!!!! (poison)
If they are the upper control arm bolt kits then you will receive 4 pieces. 2 for each control arm (where they bolt into your upper strut tower mount area). Theres different types of camber kits out there.
Also, if your TOE is off, a CAMBER kit will do nothing to alleviate this problem since its a camber kit. To fix your toe is very easy, you *can* do it yourself, but the best thing is to take it to an alignment place and have them adjust your toe and align your car completly (once you have it to your desired ride height).
Basically to adjust yoru toe is easy, you just loosen or tighten your tie rods (WARNING - doing this yourself and being unexperienced could lead to even worse alignment issues, its best to just pay the $50 and have Sears or soemthing align your car)
Old Mar 28, 2003 | 04:31 PM
Shift!'s Avatar
Default Re: Camber Woes FROM HELL!!!!!! (Shift!)
heres a site that will help you (If its Ingalls - you NEED to be more specific!!!!)
Ingalls install for 88 CRX - SHOULD be same for all civic 88-01
**EDIT**- forgot to add web addy
[Modified by Shift!, 5:31 PM 3/28/2003]
[Modified by Shift!, 5:32 PM 3/28/2003]
Old Mar 29, 2003 | 06:19 AM
alright, thanks for the help guys...
I do indeed know that the kit wont affect the toe...I'm already getting a time set up for an alignment.
Peace
Old Mar 29, 2003 | 11:32 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
just for the record, 96-00 Civic upper control arms are different, and to my knowledge there are no upper control arm bolt-type camber kits out there. On those cars, there is simply a bolt and bushing on each side of the wishbone, passing through the side of the shock tower, vs. the bolts which come up through the top of the tower on 88-95 Civics and 90-01 Integras. I think the only kits available for 6G Civics are rotating ball joints (which would change both camber and caster at the same time, no thank you) and a whole upper control arm w/ sliding ball joint (better solution, like the Skunk2 arms).
Old Apr 5, 2003 | 04:14 AM
Audi RS4's Avatar
Lover
my roommate (tecnic1) just installed them on his ITR, it took him no more than 45 minutes to install the front and the back, it's easy as hell......but jesus are they squeaky.........
SWAT
14
Aug 22, 2010 08:43 PM
jerry5150
Jun 30, 2005 08:29 PM
1quik95gsr
Apr 7, 2003 05:06 PM
X2BOARD
Sep 5, 2001 09:14 AM
