Cam/Valve Clearance Experience On CRVTEC High Compression
Old Jan 29, 2002 | 04:48 AM
Red Civic T's Avatar
New User
Default Cam/Valve Clearance Experience On CRVTEC High Compression
Just floating the question as to people's experience with valve clearance on high compression CRVTEC motors.
With aftermarket high compression pistons, this would tend to be an issue. When I ordered my Arias for 12.0:1 I asked them to cut enough relief for valve clearance on my motor with ITR cams in a b16a1 milled .030 head but can imagine that more clearance would be needed for running Toda B's for example........
Old Jan 29, 2002 | 07:53 AM
Spade's Avatar
Default Re: Cam/Valve Clearance Experience On CRVTEC High Compression (Red Civic T)
http://www.crvtec.com don't think that it will have answers however, you can look into it.
Old Jan 29, 2002 | 09:29 AM
rainforest's Avatar
First off you shoul get the motor clay tested to check for any piston to valve clearance issues. second if you tell them the lift of your cams (2001itr/ctr in lift 11.5 ex lift10.5) and that you have a milled head it should run fine.
Old Jan 29, 2002 | 11:21 AM
Spade's Avatar
Default Re: Cam/Valve Clearance Experience On CRVTEC High Compression (rainforest)
HOwever, they may make the pistons to where you cannot advance or retard the timing too far.
Old Jan 29, 2002 | 02:54 PM
Kataku2K3's Avatar
Default Re: Cam/Valve Clearance Experience On CRVTEC High Compression (Spade)
First lock ur VTEC rocker in place then clay ur motor and find the maximum amount of cam advance and retard.
Old Jan 29, 2002 | 04:17 PM
Quick 200k Mile Motor's Avatar
Default Re: Cam/Valve Clearance Experience On CRVTEC High Compression (JDMspecEG6)
"clay your motor" very clever. But i have a bit of confusion.. with the head on, block together or off?
Old Jan 29, 2002 | 07:01 PM
New User
Default Re: Cam/Valve Clearance Experience On CRVTEC High Compression (Quick 200k Mile Motor)
Well, both together natch....I will try and clay mine just to make sure - that is correct thing to do.
I think that many of the claims of Comp ratios that we are told (up to 14:1) leaves me pretty suspicious....
Old Jan 29, 2002 | 09:54 PM
C-speed's Avatar
Here's how to clay the motor:
http://www.c-speedracing.com/howto/claymotor/clay.html
noracelimit
Mar 30, 2009 12:21 PM
Used2beAb16
16
Apr 12, 2006 06:43 PM
dfoxengr
Jun 28, 2005 01:06 PM
.nate
May 6, 2005 06:26 AM
b16supertuner
10
Jan 14, 2004 02:18 PM
