Cam question for Ls/Vtec
I was wanting to know what would be the best route to take when building a 94 GSR head for a Built Ls block. Im going N/A and here are my mods.
92 Ls Block
CTR Pistons 81mm
Eagle H beam Rods (machined to fit CTR Pistons)
New Rod and Main bearings/seals
Lighten crank (stock)
Moroso Oil pan
Type R Oil pump
Gsr Water Pump
APR head bolts
Jun Gaskets (not sure on yet.
Now the Head has no work done. I want to go as agressive as I can on the Cams. So I need to know what would be best. After I buy my Cams I will start on Valvetrain.
You and post ur Ideas or your spec's from your Ls set up.
Thank alot
92 Ls Block
CTR Pistons 81mm
Moroso Oil pan
Type R Oil pump
Gsr Water Pump
APR head bolts
Thank alot
