Cam plate torque specs
Old Jun 19, 2003 | 09:49 PM
Kamin's Avatar
Default Cam plate torque specs
Ok, i no longer own a helms so i need this for cams install.
i need the cam plate torque specs for a GSR
TIA
Old Jun 19, 2003 | 11:50 PM
3rdGteg's Avatar
Default Re: Cam plate torque specs (Kamin)
20 ft. lbs. --> for the 12mm bolts
7.2 ft. lbs. --> for the 10mm bolts
Old Jun 19, 2003 | 11:52 PM
mtber's Avatar
according to haynes its...
camshaft holer bolt torque specs:
b18c1
6mm bolts - 86 in-lbs
8mm bolts 20 ft lbs
Old Jun 19, 2003 | 11:54 PM
mtber's Avatar
dont know where u got ur specs 3rdgteg but i read myne outa haynes page 2b-2
Old Jun 20, 2003 | 12:15 AM
3rdGteg's Avatar
Default Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">dont know where u got ur specs 3rdgteg but i read myne outa haynes page 2b-2</TD></TR></TABLE>straight out of the "HELM'S Manual" for the Integra.
Old Jun 20, 2003 | 12:24 AM
mtber's Avatar
lol, you sure you got the specs for a b18c1 and not a b18b ?
Old Jun 20, 2003 | 12:58 AM
3rdGteg's Avatar
Default Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">lol, you sure you got the specs for a b18c1 and not a b18b ?</TD></TR></TABLE>does ur "haynes manual" show "cam plates" for a b18b???? If it does, then there's your problem right there........buy a real manual.
Besides...what's the difference between 7.2 ft. lbs. and 86 in. lbs. anyway? Isn't it approximately the same; he knows there are only two sizes of bolts that holds the damn cam plates down....and one is approx. 7ft. lbs. and the bigger bolt is 20ft lbs.
Old Jun 20, 2003 | 01:39 AM
F1Spec's Avatar
Default Re: Cam plate torque specs (3rdGteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rdGteg &raquo;</TD></TR><TR><TD CLASS="quote">20 ft. lbs. --&gt; for the 12mm bolts
7.2 ft. lbs. --&gt; for the 10mm bolts</TD></TR></TABLE>
i usually tq the 12mm to 20ft lb
and 10mm to 10ft lb
Old Jun 20, 2003 | 02:03 AM
Kamin's Avatar
Default Re: Cam plate torque specs (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">according to haynes its...
b18c1
8mm bolts 20 ft lbs
see i have a chilton
and here is the problem
there are no 6 or 8 mm bolts. it says that same ****.
so i ask HT
but thanks guys. i appreciate it.
Old Jun 20, 2003 | 05:10 AM
94CivicSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
The heads are 10mm and 12mm, but the bolt size is measured by the shaft size, not the head size. My Helms shows all hardware as shaft size x thread pitch, like 6 x 1.25.
Old Jun 20, 2003 | 10:47 AM
3rdGteg's Avatar
Default Re: Cam plate torque specs (94CivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94CivicSi &raquo;</TD></TR><TR><TD CLASS="quote">
The heads are 10mm and 12mm, but the bolt size is measured by the shaft size, not the head size. My Helms shows all hardware as shaft size x thread pitch, like 6 x 1.25. </TD></TR></TABLE>My Helm's does too, but since I've torqued those stupid bolts about a thousand times, I just tend to translate those shaft size x thread pitch to the head size (the socket I use)....much easier.
Old Jun 20, 2003 | 10:56 AM
Rocket's Avatar
The helms manual torque specs are too high.
Do 18lbs on the 12mm bolts.
DC4cedInducted
May 21, 2006 02:30 PM
I got a honda
Oct 19, 2005 08:06 PM
Foozball26
Nov 24, 2002 01:00 PM
DOHCtorTHRUST
Nov 8, 2002 07:43 AM
hondafrk
Mar 30, 2002 09:31 AM
