cam overlapped ???
Old Apr 3, 2006 | 02:54 PM
vteczone's Avatar
Default cam overlapped ???
my set up LSvtec toda c,12.5:1CR.. i degreed the cams to factory spec..while tuning the car misses at around 7000rpm. a freind of mine had the same prob and told me that his tuner adjusted the cams due too much overlapped.is this my possible prob even though i set them to factory spec?
and if try to adjust them,how should i go about it initially..i mean advance?retard? i read that NA will only work with adjusting the intake cam??
Old Apr 3, 2006 | 04:12 PM
91DA9's Avatar
Default Re: cam overlapped ??? (vteczone)
The cams do come from the factory with slight overlap for a scavaging effect. Your mods might be affecting this too much, but not sure on this. You could try retarding the intake a bit and see what happens, but a little bit of scavage is good to pull the intake charge into the cylinder.
Old Apr 6, 2006 | 01:57 AM
vteczone's Avatar
ohh ok.. i hope so.thanks
jrp355
Feb 17, 2013 11:11 PM
teg_racer
Jun 20, 2010 08:36 AM
.I.Need.Money.
Mar 20, 2007 11:51 AM
tempsohc
Nov 12, 2006 10:29 PM
2 0 3
Jul 6, 2003 05:43 AM
