Cam Gears
Old Jun 5, 2002 | 10:58 PM
CivicEK.PDX's Avatar
Default Cam Gears
I adjusted my cam gears and set them at +4 on intake and +2 on exhaust. Nice midrange. I think that there is more to go on the top end but it may also be my restrictive exhaust (doing new setup shortly). Can I setback or advance any of the cams to pick up my topend?
My setup:
Rebuilt B16A2
Decked block .008"
ITR topend
Si AEM CAI
Middle layer OEM gasket
Skunk2 Cam Gears
Soon adding a VAFC (on its way) and an 98 Spec ITR ECU. Also putting on my JDM 4-1 ITR header, and using a USDM ITR b-pipe and chopping out the bottle necks for a 2.5 to 2.3" exhaus system. Right now my OLD Si exhaust.
Also on the ECU will have any problem with the timing or fuel cause I have a B16?
Thanks
Old Jun 6, 2002 | 12:36 PM
Default Re: Cam Gears (CivicEK.PDX)
anyone
Old Jun 7, 2002 | 02:53 AM
kinesistech's Avatar
Usually when people change cam timing they adjust them opposite each other. The reason is to create more or less overlap depneding on the application. Adjusting them both the same way together will move your power band up or down, giving you either more torque or more HP. Thats the idea behind cam gears sohc's.
id say the only problem you'll have with the ecu is plugging it in to the plugs on your si harness. They're different.
[Modified by kinesistech, 11:55 AM 6/7/2002]
Old Jun 7, 2002 | 10:14 AM
erniecars's Avatar
Default Re: Cam Gears (kinesistech)
+2 intake -1 exhaust sounds more realistic
paulzy
Sep 10, 2007 04:40 PM
AznInvasion
Sep 14, 2002 09:41 PM
TONEBONE
Aug 6, 2002 09:02 AM
shiithook
Jun 11, 2002 12:19 AM
pelotudo
Jan 18, 2002 12:20 PM
