Cam doesnt spin with bearing caps torqued?
Old Jun 29, 2006 | 05:48 AM
Neukin's Avatar
Default Cam doesnt spin with bearing caps torqued?
Hey, i was putting a d16z6 together last night and once i had the bearing caps torqued i put the cam gear on and noticed i was able to torque the bolt without haveing to hold the gear with something etc... well the cam doesnt spin at all. i used some plasti gauge and re torqued. From the dizzy side to the front of the motor i had no contact on the 5 4 and 3 bearing caps but 2 and 1 are like .03mm. btw it was with the green plasti gauge (.025-.076) so i take it the 1 and 2 are making major contact or something.. the cam cap/rocker system is could be warped? this sucks.... lmk what you think
Modified by Neukin at 9:02 AM 6/29/2006
Old Jun 29, 2006 | 07:38 AM
Neukin's Avatar
Default Re: Cam doesnt spin with bearing caps torqued? (Neukin)
anyone have any idea whats up, can you get it line bored to something so the cam fits? i dont know what to do....
Old Jun 29, 2006 | 08:27 AM
ChicagoMike's Avatar
Are you using the origional cam caps for that head??
Old Jun 29, 2006 | 09:50 AM
Neukin's Avatar
Default Re: (AddictiveAllMotor)
yes i am, i just fixed it i took the caps off another head here and it works. but i should check clearence to make sure its close to what not. The original set was warpped some.
Old Jun 29, 2006 | 10:08 AM
Default Re: (Neukin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neukin &raquo;</TD></TR><TR><TD CLASS="quote">yes i am, i just fixed it i took the caps off another head here and it works. but i should check clearence to make sure its close to what not. The original set was warpped some.</TD></TR></TABLE>
Glad it worked out, I played that game before and swapping out the cam caps fixed my problem.
Old Jun 29, 2006 | 12:48 PM
Chris22215's Avatar
since you swapped cam caps, shouldn't you have then line bored?
Old Jun 30, 2006 | 02:57 AM
Neukin's Avatar
Default Re: (Chris22215)
it would seem that way, i was just going to plasti gauge them and see how much they are off.... .002 -.006 is the range.
Tim_EG
Oct 8, 2012 08:01 PM
deepfriedjinx
Jun 19, 2011 06:36 PM
freeagent32
12
Jul 13, 2005 03:55 PM
omega11855
Oct 24, 2003 10:57 PM
216.226.142.95:27016
Jun 27, 2003 10:22 PM
