Cam caps scored, align boreing???
Old Apr 21, 2011 | 05:44 PM
trackassassin's Avatar
Default Cam caps scored, align boreing???
just got me a gsr engine, and found the cam caps to be in pretty bad shape. I've read around n found some info about align boring the caps n couldn't find the answer to my question.
Wouldn't align boring lower where the cams sit? And wouldn't that change timing?
Old Apr 21, 2011 | 07:47 PM
riceburner700's Avatar
Default Re: Cam caps scored, align boreing???
it really will depend on how much material has to be removed
Old Apr 22, 2011 | 03:37 PM
its scared up pretty good. U can actually see groove depth.
Old Apr 23, 2011 | 12:04 PM
Wow, 130 views and nothing. Come on guys, did I post this in the wrong forum?
Old Apr 24, 2011 | 06:28 AM
johnjw's Avatar
I'm going to say its not do-able. If you bore the cam bearings whats going to make up the difference, your clearance is going to be alot bigger.
Old Apr 24, 2011 | 07:27 AM
frankenghia's Avatar
It will not change the timing. It is bored directly down the center. You just use a larger bearing to eat up the difference but your cams still sit centered. If it is too scored then machining it wont help......
Old Sep 2, 2011 | 07:12 AM
Muckman's Avatar
Moderator in Chief
Where can I get Honda cam bearings or are you talking out of your ***?
1984eghatch
Jun 8, 2012 12:01 AM
90cb4door
Sep 4, 2010 08:23 AM
twistedbydezign
Aug 30, 2005 12:01 PM
omega11855
Oct 24, 2003 10:57 PM
ChiBoy
May 19, 2003 10:11 AM
