Cam cap bolt snapped!!!!!
Old Dec 30, 2011 | 12:04 PM
  #51
sc34dc4's Avatar
Default Re: Cam cap bolt snapped!!!!!
Yeah it's the sending unit not the sensor.
Old Jan 3, 2012 | 10:50 PM
  #52
Smash03's Avatar
I replaced the sender and the temp gauge is now working fine. But...now I got a new problem. My girlfriend drove the car the next morning and said it started sputtering so she pulled over and turned off the engine. As she was giving me a call, she noticed "white smoke" coming out from under the hood. So I drove over to her to check it out. I started the engine and it was running fine, although I did still hear some tapping noises. I guess I didn't adjust the valves enough and it took me awhile to get it to specs. So anyways, I looked closely at the valve cover and saw a lil bit of oil. I'm guessing she thought the blue smoke from the oil burning was the white smoke that she saw. I probably didn't seal the valve cover gasket enough or I might have to get a new on. We left the car in the lot and came back at night to get it. I decided to drive it while she drove my car. It only took about a minute or so to get form the parking lot to her house, but I noticed the temp gauge slowly rising already but I didn't drive it long enough to get to NOT. I didn't see any blue smoke at all. The engine was smooth while I was driving it normally, but when I stepped on it just a lil harder I can feel the engine sputtering. Could this be from the valve cover gasket or could it possibly be that because the engine has been sitting still for a few months and the fuel was old and that's why it was running weird?
Old Jan 4, 2012 | 06:29 AM
  #53
sc34dc4's Avatar
A valve cover gasket leaking WILL NOT make your car sputter. As for fuel maybe but not likely. I park my car every winter and it sits for 4 months or more and I start it right up in April. You have other issues that need taken care of.
Old Jan 4, 2012 | 06:38 AM
  #54
brandynEG's Avatar
get new cam cap bolts from Honda like every other time you torque them. I snapped off two in my head before I learned. and if you wanna drill the old ones out yourself, watch yhem metal shavings cause they'll ruin your day also.
Old Jan 4, 2012 | 11:18 AM
  #55
Smash03's Avatar
I already replaced all the cam cap bolts. I'm past that problem already. I guess I'll try to do a compression check and a leak down test.
Old Jan 7, 2012 | 03:11 PM
  #56
Smash03's Avatar
bump
Old Jan 9, 2012 | 12:40 PM
  #57
Smash03's Avatar
I took the car to the shop and he said that there's something wrong with the timing belt and that it was put on wrong. Homeboy wants to charge $250 to replace just the timing belt (no water pump). Says he has to take it all apart and check to see what's wrong. That sounds like too much. If its a matter of just taking off the timing belt and correctly placing it back on, then I can do that. I probably just messed up the first time I put it on. But I checked the timing marks before I put everything together and they all match up.
Here's how it rides: While it's still cold, it'll idle at about 1700 and the engine is smooth throughout stop and go. But once it warms up it'll idle around 300-400. When I step on it to go, it struggles until I get it up to about 15-20 mph, then its fine. Can anybody tell me if its an easy fix or should I let the shop fix it?
Old Jan 9, 2012 | 12:54 PM
  #58
sc34dc4's Avatar
It could be 1 tooth out of time maybe. Check it with a timing light before pulling it all apart. Then it could be 75 other things also. Just have to troubleshoot till you find it.
Old Jan 9, 2012 | 02:18 PM
  #59
Smash03's Avatar
I probably shouldn't risk driving it home then huh? Guess I'll just have to pay the shop to do it.
Old Jan 9, 2012 | 03:27 PM
  #60
sc34dc4's Avatar
One tooth out isn't a huge deal. Just baby it
Old Jan 14, 2012 | 12:55 PM
  #61
Smash03's Avatar
I've changed timing belt and water pumps plenty of time before and I've never had this problem before. Everything is set to TDC before I put the timing belt on and the tensioner is loose. I pulled the belt tightly from the water pump side up onto the intake cam and then onto the exhaust cam. After that I tighten the tensioner. I start to turn the crank counterclockwise and the belt jumps teeth on the exhaust cam. Before I started turning the crank, I was feeling around for the tension on the belt. From the tensioner to the intake cam, its a little loose. From the intake cam to the exhaust cam, its loose. And from the exhaust cam to the crank, its pretty firm. I figured I must have been doing the procedure wrong so I looked it up.
I followed the DIY here: http://www.team-integra.net/forum/bl...nt-g3-teg.html
And I still can't get it right.
Old Jan 14, 2012 | 01:32 PM
  #62
sc34dc4's Avatar
That's from the manual and how I've always done it. Do you have the correct belt? Belt and pump must match. Some are a little longer.
Old Jan 22, 2012 | 02:07 PM
  #63
Smash03's Avatar
So I changed the timing again and now it runs better, but I still get a little sputtering from time to time. Less than before tho. I'm going check the timing again and replace the valve cover gasket. I saw some oil leak from the valve cover area. It must've been worn out from taking it on and off one too many. I'll make an update on what happens after. Thanks for help.
Old Feb 10, 2017 | 04:39 PM
  #64
EdIntegrab18b1's Avatar
Originally Posted by mouab18c1
The bolt was probably worn already. I always check them whenever I take them out. Buying new ones would also avoid this situation.
​​​​​​​Hey bro i snapped 2 bolts in the head of my b18b1. I went ahead and replaced the head due to drilling problems. I am ready to get her back on the road but i cannot seem to find cam cap bolts and honda wants to much paper work just for i can order them if they even make them any more plz help..
91Honda_gsr
Engine Machining & Assembly
10
Apr 25, 2016 09:45 PM
F22Master
Jun 26, 2013 10:23 AM
Rickdogg
Jun 19, 2010 05:06 PM
SkRiBLaH
15
May 21, 2005 01:15 PM
89 CRX SI
Apr 13, 2003 12:58 PM
