california laws?
Old Jul 30, 2007 | 08:25 AM
milkmanLCA's Avatar
Default california laws?
i dont post too often but i plan to move to cali, san fran area, from chicago. does anyone know the differences in emissions between the 2?
i know that greddy is the legal turbo, but im sure not all turbo hondas are greddy in cali, how do you get around this? is n/a also outlawed? fill me in. also is san fran considered southern cal, and does northern cali have different laws.
Old Jul 30, 2007 | 09:45 AM
Crazydave's Avatar
Default Re: california laws? (milkmanLCA)
Northern and Southern california are the same state.
They are governed by the same set of laws.
HOWEVER.... the laws regarding smog may different depending on where you live. Urban areas may require an enchanced test... where as an area in the sticks you may not need to go to a test only center. Here is the map:
http://www.smogcheck.ca.gov/ft...p.pdf
more specifically here is the zip code locater
http://www.smogcheck.ca.gov/ZIPAREA/ziplookup.aspx
The enhanced test is a dyno-smog check and the standard is a two speed idle test:
http://www.smogcheck.ca.gov/st...r.htm
As far as the turbo is concerned, if it's a CARB expempted turbo (you will have a stamp or plate on the item itself, then it's legal.. otherwise no. It' it's not legal, you will have to remove it and return the engine to stock before any smog test/check.
Old Jul 30, 2007 | 09:53 AM
milkmanLCA's Avatar
Default Re: california laws? (Crazydave)
so get it tested stock, then after you pass, turbo it and your ok? what if you are pulled over and inspected?
also, waht are the rules against n/a? if you have a high compression motor, will that fail even if tuned properly?
Old Jul 30, 2007 | 11:46 AM
Crazydave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milkmanLCA &raquo;</TD></TR><TR><TD CLASS="quote">so get it tested stock, then after you pass, turbo it and your ok? what if you are pulled over and inspected?
also, waht are the rules against n/a? if you have a high compression motor, will that fail even if tuned properly?</TD></TR></TABLE>
If you get pulled over, you could be ordered to the Smog Referree.
If you are going to mess with N/A you will most likely not pass smog.
Why do you want to do all this to a car that is being driven on the street.
You can swap another motor into this car, get it reffed and be legal and reliable and not have to worry about it.
Old Jul 30, 2007 | 12:08 PM
milkmanLCA's Avatar
oh i dont plan on making a 600 hp streeet car. i was just wondering, altho i do have plans for a 350 hp street car. or maybe just an h2b. i just wanna know what can be done. any other info?
Old Jul 31, 2007 | 08:43 AM
milkmanLCA's Avatar
bump
Old Jan 20, 2010 | 05:38 PM
Mnou's Avatar
New User
bump
Old Jan 20, 2010 | 05:51 PM
hatcht9x's Avatar
San Francisco is NorCal..
any motor swap is illegal unless you get it BAR'd by the state referee and you CAN'T bar any JDM motor.. they must be USDM spec and can't be older than your car.. also you can't bar the B20 since its technically out of an SUV =/.. kindof a pain.. I would stay in Chicago.. although I don't know whats legal over there
Old Jan 31, 2010 | 06:58 PM
Vo's96Ek's Avatar
Lol you said everything I was about to say... pretty much all the above is right, but cali' is a koo spot to be.. its just we got these wack a$$ smog & ref laws... just go through reff its well worth it after, if you plan on keeping the car for a while...
Old Jan 31, 2010 | 07:23 PM
Scott_Tucker's Avatar
Yes, I'm sure you'll like the weather in the SF Bay Area vs. Chicago. What area are you planning to move to?
You can still have a high performance car out here and still be smog legal. You just can't be stupid about it. We don't have many drag strips out here but if you like driving the Santa Cruz mountains will entertain you for years.
Old Feb 1, 2010 | 08:40 AM
milkmanLCA's Avatar
whoa, this thread is old, lol but reminds me of stuff. i had a potential opportunity to move there for a job, jsut wanted to know the dilly. thanks for everyones input btw
Old Feb 1, 2010 | 07:56 PM
lolz, I didn't notice how old this thread is.
Old Feb 1, 2010 | 10:00 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
What I cant fathom is the people who bring up these old threads. How do they find them?? Do they actually look through the archives for random **** to respond too???
Old Feb 1, 2010 | 10:17 PM
milkmanLCA's Avatar
maybe they are in the same situation and instead of making another thread, they subscribe to one... its often that people dont notice the date... its not a big deal
Old Feb 2, 2010 | 02:20 PM
4g4dcruisin's Avatar
Plus, if you search for something, the results go waaaay back sometimes. its easy to not notice the date if you do it this way.
IntegType7
Jun 29, 2010 09:19 PM
livinlow
Oct 7, 2007 06:44 PM
noss88
Feb 11, 2007 02:30 PM
