Cadmium Plating ???
Old Sep 22, 2003 | 08:01 PM
. o 69 o .'s Avatar
Default Cadmium Plating ???
What is this plating process? what does it do? Is it worth the money?
This is for brake rotors
Old Sep 23, 2003 | 02:55 PM
. o 69 o .'s Avatar
Default Re: Cadmium Plating ??? (B16B)
up
Old Sep 23, 2003 | 04:01 PM
Mohudsolo's Avatar
Just like it says, it is an electroplating process that puts a thin layer of cadmium on the surface of the rotor. It will quckly wear off the braking surfaces of the rotor. On the other surfaces it will prevent them from rusting for a couple of years. A lot of places that say the cad plate are using something else(not sure what) instead because cadmium is a toxic metal and the EPA is making it much harder to use than it used to be. If having the rotors not rust for a while is worth it to you, then yes it is worth the cost.
Old Sep 23, 2003 | 06:16 PM
. o 69 o .'s Avatar
Default Re: Cadmium Plating ??? (Mohudsolo)
i live in canada, winter and salt are really rough on our cars. for an extra 15 bucks, it may be worth it... still deliberating though
triple
May 22, 2006 10:49 AM
Silent9o8
Suspension & Brakes
Dec 26, 2005 05:48 AM
RVCA97
Suspension & Brakes
Nov 2, 2005 10:10 AM
Vinceg99
Nov 15, 2002 10:00 AM
prjctCIVIC
Jul 9, 2002 06:54 PM
