CABLE TRANNY PROBLEMS
Old Feb 4, 2002 | 06:01 PM
B18b Turbo's Avatar
New User
Default CABLE TRANNY PROBLEMS
I JUST MY LS INTO MY CIVIC WITH A NEW CLUTCH AND IM HAVING PROBS WITH THE CLUTCH NOT ENGAGING ALL THE WAY.I HAD THIS SAME SWAP IN MY CRX AND I USED THE CRX CLUTCH CABLE.I PUT THE SAME SWAP IN MY CIVIC HATCH AND NOW ITS TO SHORT.SO I USED A 90 INTEGRA CABLE IT A LITTLE LONGER BUT I THINK THE CLUTCH IS STILL PARTIALLY NOT ENGAING. FOR EXAMPLE I TRIED TO DO A BURN OUT AND THE CLUTCH WONT CATCH UNITL LIKE 5000 RPM AND IF I SHIFT INTO SECOND IT BOGS AND FEELS LIKE THE CLUTCH IS SLIPPIN I CANT EVEN BARK 2ND.THE CLUTCH IS BRAND NEW.I TOOK THE BUSHING OUT OF THE CABLE AT TEH BOTTOM. I DONT KNOW WHAT TO DO.ANY OPINIONS TIPS WOULD BE GREATLY APPRECIATED. THANKS
Old Feb 4, 2002 | 06:34 PM
Kamin's Avatar
Default Re: CABLE TRANNY PROBLEMS (LS CRIX)
REPOST WITH OUT THE DAMN CAPS LOCK BOTTON
Old Feb 4, 2002 | 06:51 PM
Quick 200k Mile Motor's Avatar
what type & brand clutch?
Old Feb 4, 2002 | 08:59 PM
Armed Ferret's Avatar
did you adjust the clutch free play?
try that. you adjust the nut on the clutch cable (screw it down, tightening it) so that there's less free play in the clutch pedal.
[Modified by zoomintegra, 8:48 AM 2/6/2002]
Old Feb 6, 2002 | 12:26 AM
irev210's Avatar
Default Re: CABLE TRANNY PROBLEMS (zoomintegra)
id stop doing burnouts with a clutch that isnt grabbing
ur gunna eat ur clutch in a day
Old Feb 6, 2002 | 07:31 AM
John's Avatar
New User
Default Re: CABLE TRANNY PROBLEMS (sirhatchback)
if it's a new clutch, you should break it in first... if you do a clutch drop, you'll likely glaze your pressure plate...
danno33
12
Sep 30, 2012 08:46 PM
almostjdmeg
Oct 7, 2008 11:46 AM
kc90hb
14
Dec 28, 2004 10:21 PM
rextec
Oct 28, 2003 10:11 AM
