Cable Reel Testing....
Old Apr 11, 2004 | 02:11 PM
s13_240sx_92's Avatar
Default Cable Reel Testing....
Hey all,
I recently bought a 93 Civic that has the SRS light on and the horn doesn't work. I suspect the cable reel is at fault. I pulled the reel out and used the multimeter to measure impedence(sic?). So basically there is no continuity between the connections(colum side and steering wheel side) that I could detect with the meter..
SO is it broken? Or are there diodes or something in the reel itself that would make it test that way?
Is my testing at fault? How do you test these things?
Thanks for any info..
Old Apr 11, 2004 | 05:51 PM
Default Re: Cable Reel Testing.... (s13_240sx_92)
TTT
Old Apr 11, 2004 | 07:33 PM
ttt
Old Apr 11, 2004 | 08:48 PM
untuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s13_240sx_92 &raquo;</TD></TR><TR><TD CLASS="quote">Hey all,
no diodes or anything in there, you need a new reel
Old Apr 12, 2004 | 06:18 AM
Default Re: Cable Reel Testing.... (untuned)
thanks for the info
now i have to find one of these things
Old Apr 12, 2004 | 09:13 AM
BeerMan's Avatar
definately the cable reel, I had the SRS-and-horn-not-working-problem. Just got it fixed last night.
I ordered mine through HAP Recyclers for 46 shipped.
Just make sure you install it properly. My dumbass broke the first one I bought (25 shipped), from a seller on H-T.
http://www.haprecycling.com/
Old Apr 12, 2004 | 12:37 PM
Default Re: Cable Reel Testing.... (BeerMan)
BeerMan, how did you break it installing it? is there much of a trick to installing it? I know the yellow gear thing has to line up, but is that it??
Thanks
Old Apr 12, 2004 | 01:01 PM
BeerMan's Avatar
well, when you put it in you have to "calibrate" it. The Helms says to rotate it clockwise until it stops, about 4.5 turns. Then you rotate it counterclockwise 2 turns. I made the mistake of not turning it back counterclockwise enough turns. So, later in the day, after doing other repairs, I took the car for a test drive. When I went to turn back in to the driveway, I had the wheel at full lock to the right. I heard like a squeaking/stretching sound coming from the wheel. And by the time it occured to me not to turn the wheel anymore I heard a snap, my SRS light came on again and my horn stopped working. Basically, the ribbon, or cable inside the reel stretched too tight in the one direction.
Sorry for the wordiness.
As for the gear thing lining up, I didn't have to touch it. I think it was already lined up. Actually my friend installed the first one and I don't know if he had to do anything with that gear. I know on the 2nd one I bought, it was lined up.
allricedout
Jun 17, 2007 08:43 PM
klomast3r
Oct 6, 2005 03:11 PM
JDM-EJ1
Aug 25, 2005 04:11 AM
slowexcoupe
Nov 10, 2004 11:09 AM
PA MATT
Jun 9, 2004 01:08 PM
