Broken VSS?
Old Sep 19, 2006 | 09:10 AM
Spectrum24x's Avatar
Default Broken VSS?
Will this still work?
It's kind of hard to tell whats going on exactly, but basically this VSS is broken right at the point where it goes into the crank case the shaft that spins with the gear is still sturdy and in tact, with this VSS still work? will it be safe to use?
Old Sep 23, 2006 | 01:53 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Broken VSS? (Spectrum24x)
I doubt it will last.......esp when the power steering fluid starts getting whipped around......
90-93 B tranny......
If you've done away with power steering you could replace it, I think I have one from a JDM B16 tranny.
What color is the gear on the end?
Old Sep 23, 2006 | 02:46 PM
so lazy's Avatar
JB WELD the little *****... and go on with it!! just kidding.. i would recommend getting a new one..
so lazy's Avatar
also i'd like to add i've JB welded one before(last year) like that and its still working til this day..
Old Sep 23, 2006 | 09:20 PM
Default Re: Broken VSS? (dc2-guy)
Problem solved, i repaired my old one, and im good to go!
The pin that makes the gearspin the shaft popped out, so i put it back together, works like a charm now!
CHK4TIX
May 5, 2008 09:56 PM
CHK4TIX
Apr 18, 2008 08:40 PM
busyychild
Apr 15, 2008 05:42 PM
lildrgn2.0
Sep 11, 2003 02:38 PM
crexer
10
Apr 10, 2003 04:30 PM
