Bremo calipers off EVO.
Old Mar 26, 2004 | 07:38 PM
DC2*Integra's Avatar
Default Bremo calipers off EVO.
Is there a way to make it fit on a DC2?
Old Mar 26, 2004 | 10:25 PM
slammed_93_hatch's Avatar
Default Re: Bremo calipers off EVO. (DC2*Integra)
well you would have to kind a rotor that was around the same thickness and diameter and then you would have to rig up a mounting bracket
Old Mar 26, 2004 | 11:08 PM
Default Re: Bremo calipers off EVO. (slammed_93_hatch)
would u know a place to get the mounting bracket?
Old Mar 26, 2004 | 11:37 PM
rxse7n
Guest
Posts: n/a
No, you would have to make your own or have it made. It would be easier just to get an aftermarket brake setup instead of swapping in something made for another car.
Old Mar 27, 2004 | 10:21 PM
Default Re: (rxse7n)
im asking this because i just purchased one for a great price. If i can make it fit my car for under $500, it will be well worth it. That will still be cheaper than spending money on the spoons or endless calipers. ill post pics up this week.
Old Mar 27, 2004 | 10:52 PM
Default Re: (DC2*Integra)
i know someone knows a way. please share!!!!
Old Mar 27, 2004 | 11:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">well you would have to kind a rotor that was around the same thickness and diameter and then you would have to rig up a mounting bracket</TD></TR></TABLE>
step one find out the diameter and thickness fo the evo rotor
step two find a rotor with those deimisions that will fit your civic
step three, mount the rotor to the hub with the caliper onto the rotor and make a jig out of paper then have some one fab you up a mounting bracket
Old Mar 28, 2004 | 12:56 AM
step three, mount the rotor to the hub with the caliper onto the rotor and make a jig out of paper then have some one fab you up a mounting bracket</TD></TR></TABLE>
thanks
Old Mar 28, 2004 | 07:48 AM
Atheist's Avatar
You can actually just bore out the 4 lug setup into the rotor, if you want to. Works for me on my baer track system
Old Mar 28, 2004 | 12:20 PM
Default Re: (Atheist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist &raquo;</TD></TR><TR><TD CLASS="quote">You can actually just bore out the 4 lug setup into the rotor, if you want to. Works for me on my baer track system</TD></TR></TABLE>
i suspect that you mean redrill the center plate to 4x100, this does work, but being that its a 5 lug rotor you will be pushing your luck
ludemniac
Sep 27, 2007 08:47 AM
dayaftertomorrow
Acura TL, RL & ZDX
11
May 29, 2005 10:15 PM
Understeer
Dec 15, 2003 10:26 PM
JustLooking
Jul 9, 2003 09:01 AM
