breaking the chain link to replace timing chain?
Old Feb 7, 2018 | 10:12 PM
fuzzysig's Avatar
Default breaking the chain link to replace timing chain?
mercedes timing chain comes with a broken link and a new link to press in
you break the old chain and use the fresh link to feed the new chain through. one person holds new chain while second rotates the crank and then connect the chain link on the cam gear..
why is it not possible to do this on F20 or k series or other chain driven engines?
Old Feb 8, 2018 | 03:02 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: breaking the chain link to replace timing chain?
because those engines don't come with a crappy chain. Chains with replaceable links are only useful on such things like gates and such...not on engines.
Old Feb 8, 2018 | 07:35 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Funny,but untrue.
It simply comes down to engineering design.
Many different types of engines utilize a chain with a Master Link to facilitate changing.
Mercedes has been doing it for decades ,on engines like a 5.5 liter Supercharged V8, that produces far more power and torque than an F20 ever will, and there have been zero problems with this set up.
There is nothing wrong with using a chain with a replaceable link....
Old Feb 8, 2018 | 07:37 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
They are simply not set up that way.
Old Feb 8, 2018 | 05:03 PM
fuzzysig's Avatar
can i break the chain link and buy a new rod to install into it?
im sure someone makes the rod thats same specs as the original one
anyone knows where i could look ? or a company that makes aftermarket chains maybe?
Old Feb 8, 2018 | 06:20 PM
TheShodan's Avatar
Moderator
Does the chain actually need replacing? These Honda chains aren't like timing belts. When they're cared for by simple lubrication, they don't need to be changed.
I just sold my 185,000 miles TSX with original timing chain, and even Acura stated that it was... Perfect. .
If it doesn't need to be changed, don't.
If it does,
https://www.kseriesparts.com/HON-14401-PNA-004.html
Old Feb 8, 2018 | 06:27 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
If only every owner understood this. Clean,quality engine oil is the key to the chains life.
My RSX has 210,000 right now with the original chain.
Yet Ive changed a few dozen stretched chains in K20s and K24s over the years in engines under 100k. They were always poorly maintained vehicles...
Old Feb 9, 2018 | 02:58 AM
hondamark35's Avatar
measure. lots of measure.
if you can get maybe a used chain from somewhere (i.e. junkyard) cut it up and measure it with a set of calipers (if you don't have some harbor freight does for $19) then try to cross reference those measurements with chains that do use a master link. you could possibly then buy that master link to use with the honda motors.
Old Feb 9, 2018 | 04:45 PM
fuzzysig's Avatar
its for s2000 160000 miles chain is stretched and brand new tensioner is ticking after about 3 months
the modified tensioner is a patch not a permanent solution
motor has no leaks anywhere thats why i didnt want to break the good oem seal on the oil pan and timing case
Old Feb 11, 2018 | 11:26 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
If the the train was stretched, the vehicle wouldn't run right and you would likely get timing codes.
The chain guides are probably broken
Old Feb 12, 2018 | 02:41 PM
fuzzysig's Avatar
would i be able to see them by taking valve cover off if they re broken or not?
BB2_SI
Jun 13, 2006 09:00 PM
