brake rotors, slotted or solid?
Old Jun 1, 2003 | 08:32 PM
BIG RICH's Avatar
Default brake rotors, slotted or solid?
I want the best kind for how I drive. It's my everyday car, but I drive it hard sometimes. I heard that the slotted rotors can tear up pads? I warped my rotors, bad. after a couple hard stops there shot. right now I have stock rotors, I want something that will hold up. I've found slotted ones for $70 per rotor and solid for $25 each. I just want something that won't warp easy.
Old Jun 1, 2003 | 08:35 PM
MikeSarr_GSR's Avatar
Default Re: brake rotors, slotted or solid? (BIG RICH)
bedding in pads prevents warpage to a point, how you break in the pads insures long pad life. go with blanks and a decent pad like the axxis ultimate. thank me later.
Old Jun 1, 2003 | 09:37 PM
DJ KrunchyKracker's Avatar
Default Re: brake rotors, slotted or solid? (MikeSarr_GSR)
yea i would go with a good pad like a hawk or axxis and buy some brembo blanks. they are pretty cheap and are a pretty good disc overall. plus with the low cost if u do start to warp them they r cheap to replace
Old Jun 1, 2003 | 09:50 PM
Default Re: brake rotors, slotted or solid? (DJ KrunchyKracker)
keep in mind, breaking them in properly will help avoid warpage... and turning them works too.
Old Jun 3, 2003 | 02:22 PM
PupaScoopa's Avatar
That and warming them up before you expect to put some heat into them is good. The way drilled/slotted rotors crack or warp is because the heat isn't consistent across over the entire rotor. The hot spots expand faster than the cooler ones = crack or warp.
Old Jun 3, 2003 | 03:34 PM
turbo Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ KrunchyKracker &raquo;</TD></TR><TR><TD CLASS="quote">yea i would go with a good pad like a hawk or axxis and buy some brembo blanks. they are pretty cheap and are a pretty good disc overall. plus with the low cost if u do start to warp them they r cheap to replace</TD></TR></TABLE>
I was told the same thing. Although i plan on going with either Hawk or Porterfield! Also, I believe Summit has the best deal on Brembo blanks.
Old Jun 4, 2003 | 10:33 AM
Default Re: brake rotors, slotted or solid? (turbo Si)
cobal friction tech sells great replacement blanks they use on the track for 29.00, I have them on mine with about 500mi on them so far on GT-Sport fronts. I still need to put in my rear axxis ultimates. My system definately needs bleeding as with the stock fluid will boil on these pads easily... gonna put in some super blue. Plan on doing that this week these brakes BITE
Jaydeep
30
Oct 21, 2016 07:22 PM
xiong28
Suspension & Brakes
Oct 6, 2008 06:13 PM
H2290
10
Jul 28, 2006 01:56 PM
LudeyKrus
Jun 10, 2003 03:40 PM
WuShu
Aug 18, 2001 09:55 AM
