Brake line boo boo
Dumb mistake; while installing stainless steel braided lines (Neuspeed), I overtorqued the banjo bolt and squished the bejusus out of the two little copper washers that came with the line kit. As you can imagine, it began leaking immediately, I cursed myself profusely and proceeded to remove the damaged washers and replaced them with a pair intended for the rear caliper (same size, I just had not done the rears yet).
So, now I have only enough washers for one side in the rear. My question, can I just use new OEM Honda washers for this, or is there some reason I specifically need the copper ones?
Yeah, I figured at worst I could call them and order new washers from them, but running to my local H dealer is much simpler. I got pmed by bseries about it, and he used Honda washers with his ss lines, so I will be going that route as well.
Thanks for the help.
Pandahatch
Jul 2, 2023 09:06 PM
Sinner
Oct 20, 2003 05:03 PM
