brake disc
Old Feb 14, 2007 | 05:31 PM
CrX-WoRlD's Avatar
Default brake disc
how to remove the 2 bolts that hold the brake rotors?.....thy are stuck there!!!
Old Feb 16, 2007 | 12:17 PM
4WSi_guy's Avatar
Default Re: brake disc (CrX-WoRlD)
I assume you mean the phillips head screws? Drill the heads off...once you get them drilled the rotor will come off...then use a pair of vise grips to get the rest of them out...you dont have to put new ones back on if you dont want to...the wheel holds the rotor on...they just help with brake chatter...but you can get new ones at the dealership. I tried to use a impact screw driver once...even that didnt work. I've drilled these on all my cars. GL
Old Feb 16, 2007 | 03:44 PM
PHDZINE's Avatar
Impact screw driver...but only if you haven't already stripped the screw!
Old Feb 17, 2007 | 03:18 PM
b16nonoy's Avatar
impact screw drive and a 2lbs sledge hammer...if you stripped the phillips pattern already...your gonna have to drill them out..
Old Feb 18, 2007 | 01:55 AM
Surfjunkie44's Avatar
Default Re: brake disc (b16nonoy)
Done on at least three or four cars... it's just the way it goes with Hondas. For everything else we get out of them I'd say it is worth that lil' headache...
b20acura
26
Aug 29, 2011 08:03 PM
MrDomino
May 15, 2008 03:42 PM
fiebru1119
Nov 9, 2002 12:06 PM
alu95
Jan 20, 2002 11:46 AM
leechungsr
Aug 25, 2001 03:39 PM
