Braided fuel line for CTR EP3
Old Feb 1, 2006 | 12:03 AM
sk8flex's Avatar
Default Braided fuel line for CTR EP3
Is there a parts list and/or tutorial available for the installation of a braided fuel line for the EP3? I had a look at the Earlīs online catalogue but couldnīt find any info.
I also need a T-joint with a 1/8PT thread to fit a fuel pressure gauge. Any links to shops where I could get this?
Any help is much appreciated.
Old Feb 1, 2006 | 04:39 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Braided fuel line for CTR EP3 (sk8flex)
This is all pretty much trial and error. You have to have an idea of what size fittings you need for your setup. You should just pick a size and go from there, buy adapters ect ect. Its very helpful to look this stuff up online but if you have a local shop, its worth it to spend the extra money so that you can take parts back easily if they dont fit and get the one that you need.... You should ask stan @ http://www.fast-turbo.com what you need. He'll have a pretty good idea on what you'd need.
Blaze
Old Feb 1, 2006 | 05:26 PM
Redline96LX's Avatar
* B A N N E D *
You guys have the 5 door civic hatch over there, im guessing it probably takes the same hardline fittings in the front, and the same banjo bolt attachment. See if the hardline fitting for the back is similar to that of the 6th gen civic, then get lines from a 2000 Civic Si.
Old Feb 1, 2006 | 10:33 PM
sk8flex's Avatar
Default Re: Braided fuel line for CTR EP3 (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Its very helpful to look this stuff up online but if you have a local shop, its worth it to spend the extra money so that you can take parts back easily if they dont fit and get the one that you need....</TD></TR></TABLE>
Thanks for your answer. My problem is that I donīt have a local shop where I can drop by and take some different parts back in case they donīt fit.
I can order Earlīs hose and fittings online but I have no clue which parts to pick and I guess I canīt send them back after having test fitted them.
Old Feb 2, 2006 | 08:56 PM
Blaze45's Avatar
Brrraaaap!
O geez sorry I didnt see where you @. Sorry I couldnt of been more help...
Old Feb 3, 2006 | 02:15 AM
sk8flex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">O geez sorry I didnt see where you @. Sorry I couldnt of been more help... </TD></TR></TABLE>
No worries, thanks anyway.
Iīve seen a parts list on another forum before but only suitable for K20 swaps.
95hybridcivic
Jan 27, 2003 09:23 AM
Tegra
Jan 4, 2003 08:51 PM
