Bought an EK hatch could use some advice
Old Sep 7, 2022 | 01:38 PM
Touchcheeks's Avatar
Default Bought an EK hatch could use some advice
So I finally managed to get a project hatch it runs and drives I’m hoping to make it run smooth and daily it.
at the moment I ordered a new suspension because the one it had bounces like crazy.
The issues that the car is having is sometimes like 3rd/4th gear around 3k rpms it will lose power and bog.
the car has a D16y7 and was manual swapped.
The ECU is a P2E and the trans has a sticker that says E7F.
i checked for codes and at first got this huge list: p0113, p0141, p0700, p1758, p1706, p1768
i cleared them and took it for a spin checked again and these came up: p0141, p0700, p1758, and p1768.
I googled and the only thing I could come up with was the ecu being for autos but when I search for P2E ECUs they say it’s for manuals so I’m confused.
As far as the losing power issue I can see the oxygen sensor wires cut under the car maybe that’s the problem?
car turns right on and idles good goes through gears fine.
any advice would be highly appreciated thank you
2jz240sx
Jul 18, 2019 03:28 PM
hmotors
Sep 13, 2009 11:37 PM
Mhollaek9
Oct 11, 2006 06:34 AM
