Bottom End Refresh: Honing a cylinder.....DIY question?
Old Jul 3, 2006 | 08:10 AM
1JDMDOMINICAN's Avatar
Default Bottom End Refresh: Honing a cylinder.....DIY question?
I'm going to help my buddy rebuidl his bottom end with new rings and bearings for his B18B....we want to prep it for the LS/VTEC conversion. He has all the parts that we need for the conversion, but he wants to refresh the bottom end with new rings and bearings. The question I have is, should we hone the cylinders? He says that its not necessary, but I'm sure we have to hone them so that the rings have a fresh new surface to grab onto. Correct me if I'm wrong, but the motor has about 120k miles on it as of now and I'm sure honing would be better. Its his car so I'm just helping him, but if he wants to cut corners, then its on him. I recommend honing but its up to him.
Another question I have is, has anyone on here honed their own cylinders? I saw my uncle do it once on a Toyota 22R motor, so it doesn't look so complicated...what is the process and materials that I need? I know I need oil and a honing stone and a drill. Other than that, what else do I need? What procedure should I follow?
Any input would be greatly appreciated asap considering we are starting this project this week.
Thanx guys!
Old Jul 3, 2006 | 11:50 AM
anyone?
Old Jul 3, 2006 | 04:11 PM
mmuller's Avatar
Mad Scientist
Default Re: (1JDMDOMINICAN)
i would measure cylinders for egg shaping, its there; just how much.
PTWC could be off or almost there. if thats the case boring to the next size up is the answer.
if the crosshatch is there and the cylinders are not off by a lot you could just put the rings in or give it a de-glaze with a ball hone.
Old Jul 5, 2006 | 12:38 PM
cool. thanx!
Old Jul 5, 2006 | 03:23 PM
96 GSR-T's Avatar
You got the motor apart, honing is not that much money..... get it done, it pays in the long run.
Old Jul 6, 2006 | 12:37 PM
its not my motor..its my buddy's...i told him to send it outy, but he doesn't wanna go thru that he says...he'd rather do it ourselves and put the motor back together rite away...i just dun wanna cut corners.
Old Jul 6, 2006 | 02:38 PM
unknown0001's Avatar
I've honed a few engine with the stone-type engine hone device and never had problems.
I did it on my b18b and the engine is in the car with 1500km so far and it's running great.
24TEN
Jul 20, 2008 04:33 PM
KooK
Feb 4, 2006 09:08 PM
gramentz
Jun 5, 2005 08:07 AM
scribe
Feb 17, 2004 06:56 PM
senpai
Jan 27, 2003 05:58 AM
