bottleneck theory
Old Jan 2, 2003 | 12:16 PM
SIK IN DA HED's Avatar
New User
Default bottleneck theory
i got a 2.5 exhaust.. from the downpipe all the way back... except... i have a gutted stock cat that i use for racing. now... i believe that i might be bottleneckin with the stock cat...
any proof or solid facts as to how a 2.5 carsound cat would benefit me more than the gutted free flowing cat? cause if i dont really need to spend the money on one.. i rather just keep the gutted cat on.
Old Jan 2, 2003 | 12:33 PM
PupaScoopa's Avatar
Default Re: bottleneck theory (dlplayboy)
A straight through pipe (test pipe) would provide the best flow. The problems with a gutted cat is that you have a small inlet, then a large chamber, then back to a small outlet... which makes turbulence... which slows the flow.
Old Jan 2, 2003 | 12:40 PM
sslude's Avatar
Default Re: bottleneck theory (PupaScoopa)
yes get a test pipe, they are only 35 i believe. but it might throw codes at you.
Old Jan 2, 2003 | 01:02 PM
Shawn C's Avatar
In The Garage
yeah, id take that gutted factory cat and cut it apart. cut a piece of 2.5" pipe the size of the large chamber of the cat, and make a bolt-on test pipe, welding the 2 flanges to each end. you can even weld on the O2 threading if your car has one on the cat. youll have much better results, and youre lookin at about 5 bucks, considering you or a friend can weld. also, id recommend spray painting it with 1500 deg. silver or flat black paint, to protect it from rusting.
[Modified by 22lbGS-R, 10:03 PM 1/2/2003]
Fat Chick Magnet
Aug 4, 2006 04:33 PM
Rhetoric
Jul 14, 2002 12:13 AM
SiRkid
May 6, 2002 01:02 PM
QuestRacing-TypeR
Apr 2, 2002 02:04 PM
vtec power
Jul 30, 2001 09:32 AM
