Borrowing ECU
Old Jun 21, 2010 | 09:58 AM
whited's Avatar
CRX God
Default Borrowing ECU
I just helped my buddy put a D15z6 in a 96 civic ex. It ran but had a check engine light. A tech scanned the computer, and thinks the ECU could be bad. Do you think it is a bad idea to let him borrow my 96 civic ex's ECU to test that theory?
Old Jun 21, 2010 | 05:30 PM
fcm's Avatar
fcm
Old Fart
Default Re: Borrowing ECU
Yes, if there is a short in his system, it can take out your ECU also, better to put his ECU into your car to test it.94
Old Jun 21, 2010 | 05:39 PM
crazyheadrush's Avatar
Is the ecu OBD 1 or 2 that u are using. Try opening the ecu and smell it to see if uts burnt or may have humidity corosion.
Old Jun 23, 2010 | 06:39 AM
whited's Avatar
CRX God
That is a good idea. Thanks
whited's Avatar
CRX God
both obd2
Old Jun 23, 2010 | 04:05 PM
Then if it the tech couldnt read the ECU the i think most likely is toast. BTW dont try his in your car.
Old Jun 23, 2010 | 10:32 PM
I add if the ECU is JDM than it will not read it either.
Old Jun 24, 2010 | 01:31 PM
94EG8's Avatar
Seagull Management
If the backup fuse (usually in the underhood fuse panel) is blown, the scanner wont connect either.
SOHC_MShue
Oct 14, 2002 11:22 AM
