bogging and misfire in B16A. help...
Old Jan 27, 2003 | 08:37 AM
WAFFLES's Avatar
Default bogging and misfire in B16A. help...
OK, last night on the way home I noticed some hesitation. When I fired it up this morning, whitish blue smoke started pouring out, and it smoke all the way through the rpm, and it lacks power severly. It idles at about 500rpm, and will fall down to about 100rpm and just sit. It's drinking gas horribly. And when I stopped at the gas station, there were sludgy pools of gas in the muffler tip. I just changed the spark plugs, thinking that I fouled one. All were completely black, but the tips were in good shape. I'm not sure what else it can be besides the plug wires, distributor, or valve lash. Please help me out here.
Old Jan 27, 2003 | 08:54 AM
Desslok's Avatar
Default Re: bogging and misfire in B16A. help... (Blake K.)
Blue smoke usually means oil burning. I would do a compression test.
Old Jan 27, 2003 | 10:30 AM
Civichatch2k's Avatar
Default Re: bogging and misfire in B16A. help... (sp)
bump...its not dark blue like oil.
Old Jan 27, 2003 | 12:06 PM
Philly_NBP_R's Avatar
Default Re: bogging and misfire in B16A. help... (Civichatch2k)
could be your'e head gasket - you may be leaking coolant into the combustion chamber - that will cause whiteish smoke, and would explain the loss of power. I would bring it to a mechanic, or pull off the cylinder head if you feel comfortable w/ that stuff...
Old Jan 29, 2003 | 04:41 PM
Spade's Avatar
Default Re: bogging and misfire in B16A. help... (WAFFLES)
Compression test needed.
Old Jan 29, 2003 | 05:44 PM
Dan1krzysi's Avatar
Default Re: bogging and misfire in B16A. help... (Spade)
Do a compression test, could be head gasket. had same thing happen to me
Red-Rag-B18
May 4, 2010 07:04 PM
andystart
14
Oct 15, 2004 08:52 AM
Civic4drR8cer
Jul 13, 2003 11:17 AM
GOTNOS
Apr 16, 2003 04:37 PM
4drGSR
Jun 19, 2001 05:15 AM
