blox racing cams type a
Old Dec 28, 2004 | 01:46 AM
germanEE8's Avatar
Default blox racing cams type a
Hey,
I've heard the blox racing cams type a (stage1) outperform the ctr/itr cams.
I don't want to use stage2 cams, because I don't want to change my stock compression (b16a1 engine) and don't want to use titanium retainers (because of the wear).
The price of the blox cams is lower than new ctr cams, so I've thought about getting blox type a cams and a jdm itr valvetrain.
Who's got information on these cams? - specs,dynos,opinions? everything is welcome.
thx in advance,
marc
Old Jan 5, 2005 | 11:30 PM
vinasity's Avatar
Default Re: blox racing cams type a (germanEE8)
from what i heard bloxA,B wicked and skunk 1,2,3 cams are the same but im not 100 percent sure
Old Jan 13, 2005 | 01:41 PM
ptoledo's Avatar
Im running type A camshafts. with a blox manifold. Im pretty happy with it. My base run was 170. I dynoed at about 180 whp 178 to be exact.(my edit) This was all on a P28.
I actually dont have the cam specs at the moment, but I do have them somewhere. The lift and duration is slightly more then the CTR cams. The Skunk2 stage 1 have higher duration (in./exh.) when compared to blox type A. From what I remember, correct me if I am wrong, the Blox Type A Intake cam has higher lift when compared to the skunk2 Intake cam. Ill try to get you the numbers asap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinasity &raquo;</TD></TR><TR><TD CLASS="quote">from what i heard bloxA,B wicked and skunk 1,2,3 cams are the same but im not 100 percent sure
My mechanic who is a blox distributor told me:
Wicked = Blox (but repackaged as wicked)
Skunk2 specs are different
Old Jan 15, 2005 | 03:44 AM
germanEE8's Avatar
Default Re: blox racing cams type a (StreetFameGSR)
Thx for replies, are you using stock valvetrain or itr/ctr valvetrain?
Old Jan 16, 2005 | 10:28 AM
ptoledo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by germanEE8 &raquo;</TD></TR><TR><TD CLASS="quote">Thx for replies, are you using stock valvetrain or itr/ctr valvetrain?
I am using supertech valvspings and retainers. They edit(springs) have 70lb seat pressure. 2lbs less then skunk2.
Old Jan 17, 2005 | 05:07 PM
ptoledo's Avatar
Here is a quick comparison.
1997-1999 ITR
INTAKE lift - 11.5 mm, duration 240 @1mm
EXHAUST lift - 10.5mm, duration 235 @1mm
2000-2001 ITR
INTAKE lift - 11.5 mm, duration 243 @1mm
BLOX TYPE A
INTAKE lift - 11.734 mm, duration 247 @1mm
EXHAUST lift - 10.67mm, duration 239 @1mm
SKUNK2 STAGE 1
INTAKE lift - 11.582 mm, duration 252 @1mm
EXHAUST lift - 10.82mm, duration 249 @1mm
Old Jan 17, 2005 | 05:19 PM
chero112's Avatar
hay StreetFameGSR are you happey with your blox cams, any problems,,,,
Thinking about buying a set, ut I really don't know nothing about blox, and + alot of people say blox merchindes are shitty......
Old Jan 17, 2005 | 06:05 PM
ANR008's Avatar
Default Re: blox racing cams type a (chero112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chero112 &raquo;</TD></TR><TR><TD CLASS="quote">hay StreetFameGSR are you happey with your blox cams, any problems,,,,
</TD></TR></TABLE>i bet the people saying blox is shitty have never had first hand experience with blox parts.
i sell blox cams all day long and every one of my customers are happy with them.
Old Jan 18, 2005 | 09:17 AM
ptoledo's Avatar
I love em!!
Great with my stock block Gsr.
If you want a more aggresive set up, go with the stage 2's and bump your compression.
Old Jan 18, 2005 | 01:57 PM
chero112's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetFameGSR &raquo;</TD></TR><TR><TD CLASS="quote">
I love em!!
If you want a more aggresive set up, go with the stage 2's and bump your compression.</TD></TR></TABLE>
I want to keep my block stock, looking for something that would work with that......
Old Jan 18, 2005 | 04:31 PM
ptoledo's Avatar
I would go with the blox type A then...
Old Jan 18, 2005 | 06:37 PM
chero112's Avatar
can you give me a website or there site address so I can do reading anout there cam's thanx
Old Feb 1, 2005 | 11:32 PM
Resident Evo's Avatar
Should I go with type A or B? I just installed CTR pistons and ITR valvesprings on my b16. But engine not installed into car yet.
All I plan on doing is cams, cams gear, obd2 to obd1 and p28 chipped ecu. Daily drivin
Old Feb 3, 2005 | 10:55 AM
ptoledo's Avatar
Default Re: blox racing cams type a (EBP-Si)
Just an opinion, I would go with Type B since you are running high compression.
Just be sure to upgrade the springs and retainers. I dont know if the itr springs can handle a type B lift...
Old Feb 12, 2005 | 01:20 PM
TrackSpeedRacing's Avatar
The blox racing tuner series type a cams are excellent for stock bottom end b-series engines. For all the specs and pricing information check us out at http://trackspeedracing.com/si...XCM-T. We are currently offering a sale on all blox racing products. Fast shipping and quality customer service.
Cummins4LF
Feb 8, 2018 05:34 AM
grunt111
Sep 30, 2011 02:53 PM
da_driver_15
12
Jan 28, 2009 07:20 PM
shadowstylz
Jul 15, 2003 08:41 AM
EGkTiOn_CiViC
Aug 19, 2002 05:32 PM
