blox oil pressure sender
Old Aug 13, 2018 | 03:43 PM
1320vickers's Avatar
Default blox oil pressure sender
i have an eletric sender for a blox oil pressure gauge with trhe sensor itself grounded to the head and the sending wire running straight from a toggle switch, it gets power the light comes on and i see the needle barely move when its switched on. the problem is i havent started my motor i was trying to get pressure before i tried but i crank and crank but cant build up anything, is thhis because its not running or is something else going on?
Old Aug 14, 2018 | 02:29 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: blox oil pressure sender
why would you wire up a sensor to a toggle switch?
Old Aug 14, 2018 | 06:13 AM
Not the sensor itself the gauge is in the toggle
JimRaynor90
Mar 2, 2015 05:41 PM
jdubEP3
Jan 26, 2012 05:23 AM
OGMatt
Aug 15, 2011 01:11 PM
Silvrteg
Oct 15, 2007 12:08 PM
Mr HYDE
Mar 29, 2007 06:02 PM
