Blowby questions...?
i have nearly 600 miles on my car since i did the rebuild. my setup consists of arias pistons (81.5mm) with a .0035 piston to wall clearence that was measured on each hole and all the correct piston ring end gaps. at first i had alot of blowby, but now that my motor is almost broken in it seems to have gotten worse. at idle there is a nice trail of smoke coming out of the breather filter on the valve cover and it stinks in the car. is this normal or what? the good thing is that it seems to go away when i rev it a little. i have an 8.57:1 compression ratio and iv got about 175+-2psi in each cylinder.
thanks
thanks
