Block Girdle
Old Nov 8, 2002 | 11:40 AM
89SiR's Avatar
Default Block Girdle
Wondering if anyone knows if the girdle from the type-r will fit on a B16? And if so what parts will I need and what mods?
Thanks
Old Nov 8, 2002 | 12:58 PM
Charlie Moua's Avatar
Default Re: Block Girdle (89SiR)
why do you want one? do you think it will help or something?
LOL i have a ef too.
well the B16a don't really need it because they have a much better rod to stroke ratio which means that less frition, heat, and stess on the block it self......so simply put if you have a regualar B16 with I/h/e/ and other small goodies and some good gams you still won't need it. unless you reving your B16a above the 9.500rpms..... but i highly doubt that your cams can make power that high.
peace Hope that helps.
Oh... not sure if ITR/GSR block guirdle will fit the b16a.
But I do know that they will work in B18, B20.
if you really want one get a Z10. they make it specifially for it so you won't ahve to do any mods.
Old Nov 8, 2002 | 01:27 PM
Kataku2K3's Avatar
Default Re: Block Girdle (Charlie)
Z10 will work fine but just as Charlie said you don't really need it on a B16...but it does help with vibration on the bottom end. You'll notice when assembling a bottom end with a girdle how much stiffer it really is just being connected to 3 main caps.. Latez
[Modified by JDMspecEG6, 2:28 PM 11/8/2002]
Old Nov 8, 2002 | 02:00 PM
89SiR's Avatar
Default Re: Block Girdle (JDMspecEG6)
I'm going with high boost / nitrous and I thought it would be good security. Its not just for a stock B16.
Old Nov 8, 2002 | 02:32 PM
Kataku2K3's Avatar
Yea it's a good thing to have like we were saying, and with those mods you would be fine stock too. With your setup depending on how much you do, it's a good thing to have but there is nothing that makes you absolutely need it.. I like the B18C the best. Comes with a girdle, R/S isn't really bad, good power, and reliable. Laterz
[Modified by JDMspecEG6, 3:34 PM 11/8/2002]
Charlie Moua
Jul 14, 2007 12:27 AM
Jdmb16sir2
10
Apr 10, 2007 06:46 PM
stoned_sol
Sep 12, 2004 08:07 AM
Tinker219
Jul 8, 2004 11:31 AM
EF_LSVtec
Aug 28, 2003 07:10 PM
