BIG VTEC CAM QUESTION!!
i just got a set of cams that are a bit bigger then skunk 2 stage two cams. i was told and have also seen for myself. that it wont go past vtec unless its full throttle. i was told this is cause the cams are so big. i have the calve train and everything to go with it. can someone explain to me why this happens.
It's called overcamming, and it occurs when the motor isn't flowing enough air for all the lift that the cams are producing, and there's no velocity to the intake charge. You lose torque and everything is slow. It's the same reason you can't have VTEC on all the time, the car just won't run like that. If you can, raise the VTEC point to minimize the effects, or get some smaller cams.
Hi im new user from the other side of the pond need some help, got a accord type-r 2002 model and i want to change the start point of my v-tec now at 5500rpm seen this on the web( Apexi V-AFC 2) the product say it can do it , my just not sure what it my do to my engine have u herd of this product before and how low can u start your v-tec safely thanks for your time
