Big Piston Problem.. Please Help!!
Ok, I pulled the head off this engine i bought about 3 months ago and this is what i found... The #1 piston is set about 1\8th of an inch lower than the other 3 pistons. When the #4 piston is at full extension up, the #1 is again 1\8th inch lower and never makes up that difference... Later im gunna pull the rod out and see if the bearings are screwed up but what else could this be? Please help!
Thanks,
-Nick-
Thanks,
-Nick-
Sgt, question for ya... Since my engine is all ripped apart i think im gunna get some 12.1:1 comp pistons... can i still use stock rods and head gasket with the upper com ratio? Do i need anything else besides 94 octane fuel?? Thanks!
i would change the rods you have in the engine since it may seem like you have a bent rod.......you dont want to mess around with those anymore......
you "can" use a set of stock LS rods as long as you dont plan on over reving the hell out of that engine.........or else find yourself a set of eagle rods.....they are relitivly cheap and very strong......get yourself a good set of forged pistions and you will be set!
stock head gasket will be fine.......
well if its a bad rod, i say replace them all. dont take a chance with stockers that run around $75 a piece. buy brand new rods for 350+ that r aftermarket. this is insurance for ur motor and ur pocket book. dont b a cheapass.
Anyone know a good website where i could get eagle rods and some good 12.1:1 or higher pistons? thanks! I think the investment for the 2 should be well worth it .
-Nick-
-Nick-
jetlude
Jan 18, 2008 04:43 AM
