Best ecu for GSR setup in an EF hatch?
I have searched and didnt come up with anything. So what would be the best setup for a 95 b18c1 in a 91 hatch? Skunk2 manifold, so secondary butterfly is irrelevant.
Mugen Chipped pr3
p72 conversion
p28 conversion
Plans are to mildy mod (i/h/e, possibly some mild cams in the future) will stay n/a
Please explain the significance of your response. tia
Mugen Chipped pr3
p72 conversion
p28 conversion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PotatoePAPA »</TD></TR><TR><TD CLASS="quote">currently it is wired for obd0. I am just curious if it is worth it to go obd1 and why?</TD></TR></TABLE>I'd get an OBD-0 to OBD-1 harness and then you can utilize the p72 since it will be able to activate the secondary butterflies. If you deactivate them or switch intake manifolds you'd still be able to used a chipped p28 or a p30.
Brian
Brian
I got the same set up i didnt feel like doing the obd1 conversion so i just used a b16 dist, injectors and a chipped pr3 so i only had to run 1 02 sensor and 4400 vtec crossover, and 8200 rev limit and i smoke v8 mustangs all day long
only if you want to be smog legal and get BAR certified for Cali.
Nightkidef9
Aug 6, 2006 07:49 AM
