Bent ValveS!!
Old Apr 17, 2003 | 01:30 AM
preludacris's Avatar
Default Bent ValveS!!
Modified by preludacris at 9:25 PM 5/29/2003
Old Apr 17, 2003 | 01:54 AM
MikeSarr_GSR's Avatar
Default Re: Bent ValveS!! (preludacris)
it is a good ideal to measure the spring pressure after an event like that.
the retainers need to be inspected. after missing shifts and overreving like
that the springs tend to fatigue a bit due to the valvetrain bind that occurs.
if you reuse the parts, replace the retainers... check the installed heights
on the springs. what cams are we talking about here>? that makes a
huge difference in baking this cake. HG definately needs to be replaced.
$50 insurance policy. The valve guides could be replaced on the exhaust
side. have the valves re-lapped and checked... replace what is bent. if intake
are fine, keep em or go ITR> repalce the valvestem seals. I suggest ITR LMAs for running taller cams.
Old Apr 17, 2003 | 03:46 AM
Default Re: Bent ValveS!! (MikeSarr_GSR)
He has ctr cams. thanks for the input
GReddy SI
Oct 31, 2009 07:19 PM
phil_space
Sep 6, 2009 11:04 AM
boostinb18
Oct 26, 2002 12:31 PM
Resurgent
Sep 17, 2002 10:33 PM
civicguy
Dec 27, 2001 04:22 PM
