BDL B-series fuel rail installation help
Hi,
I've recently bought a BDL B-series fuel rail, and I was wondering what the threaded hole (seems like M14x1.25) on the bottom, in between injectors 2 en 3 is for.
There does not seem to be a plug included for it.
The hole is visible in this picture:
remote pressure gauge maybe?
I tried contacting BDL, but their contact page seems down.
I would really like to know about all the threads on the rail, to figure out what AN adaptors I need for my AN-6 plumbing.
I'm not that familiar with all those U.S. standards (i'm european).
Modified by Pandor at 6:09 AM 9/21/2008
It's for additionaly fuel supply, return, what have you.
The BDL rails are -8AN inlet/outlet. I believe that auxillary thread you're referrign to is -6AN.
Thanks a1320addict, I think I'll just include a -6AN plug in my order for the bottom port then, as I haven't heard back from k20tuned yet.
Or I could just plug the outlet port (one of the -8AN) and use the bottom -6AN as a return, to my external FPR.
But won't that disturb the flow/pressure?
Your fuelrail should have came with the plug and some fitting's. If you need a set just call the number in my sig and ill give them to you for free just pay for shipping. Im a BDL dealer and I will take care of the problem for you and bring it to BDL's attention.
Highend autosports
Mike
Highend autosports
Mike
Thanks for the offer Mike.
I did receive everything else on the package (o-rings for the injectors, banjo bolt and AN-10 plug for the outlet.). I'm just missing the AN-6 plug for the bottom auxiliary inlet/outlet port.
Since k20tuned hasn't got back to me about the problem, I guess i'll just include a AN-6plug when I oder my AN conversion stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike@Highend Autosports »</TD></TR><TR><TD CLASS="quote">Your fuelrail should have came with the plug and some fitting's. If you need a set just call the number in my sig and ill give them to you for free just pay for shipping. Im a BDL dealer and I will take care of the problem for you and bring it to BDL's attention.
Highend autosports
Mike</TD></TR></TABLE>
wow.. talk about great service. I dont know you or your shop but this just makes me want to buy some sh*t off you!!
Highend autosports
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnez »</TD></TR><TR><TD CLASS="quote">
Thank's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dyingwish »</TD></TR><TR><TD CLASS="quote">Mike, I have the same rail, mine also came without any hardware....I'll give you a ring as well.</TD></TR></TABLE>
Give me a call and ill take care of it.
Mike
</TD></TR></TABLE>Thank's
Mike
I was just thinking, Wouldn't it be better to make it a dual feed fuel rail?
So, use a Y-splitter on the fuel line and connect it to both ends of the rail.
Then use the bottom -6AN hole to run the return line (to fpr).
Modified by Pandor at 12:42 PM 10/29/2008
not to bring back a dead thread but can it bu used as a fuel supply for a nitrous kit just asking bc i have a wet kit (venom vcn-2000) dosnt need a fuel feed like the nos fogger kit having 2 solenoids i only have one but could it be used for that fuel supply
Datum1Tuning
May 22, 2004 11:30 AM
vtecvoodoo
Jan 4, 2003 10:16 AM
