battery info
about how many cold cranking amps are normal honda car batteries?
is it better to have more amps/hour say 22 as opposed to 13?
and why is it harder for a battery to work cold anyways?
Most Honda Civics require 410 cca (cold cranking amps) A few 2003 require 435 cca. This is a rating at 0 F not to be mixed up with ca (cranking amps). ca is a 32 degree reading. Also Civics will take a group 51 or group 51R.
Batteries have an internal resistance. This resistance increases with cold temperatures. This resistance is in series with the starters' resistance. When current flows through a series circuit, voltage drops occur across these resistances. So the higher the resistance of the battery, the more voltage that will be dropped across it and not across the starter.
One common solution to this, on very cold days....turn your headlights on for a few minutes. Current flows and heat is created, thus decreasing the internal resistance of the battery.
Modified by EE_Chris at 12:44 PM 3/12/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">
If a battery will supply 100 amps per hour, then it will supply 50 amps for 2 hours....the opposite of what you were thinking. The lower the current draw, the longer the battery lasts.</TD></TR></TABLE>
thast what i said. read above
