balancing lsvtec?
Old Nov 14, 2002 | 03:57 PM
1RMDave's Avatar
Default balancing lsvtec?
I have a b18a with eagle rods, stock pr3 pistons, stock b16 flywheel. i can use the stock b18 flywheel if i should? does this need balancing?? i mean the rods should come balanced and my stock pistons should be balanced. the motor will probly see 8500 rpm, but shouldn't all that already be balanced?? it would be nice to save $200
Old Nov 14, 2002 | 05:08 PM
VWkila's Avatar
Default Re: balancing lsvtec? (OneStunna)
I'm getting my rods/pistons balanced, eventhough I was told it wasn't necessary.
As far as flywheel is concerned, they balance the flywheel, pressure plate and crankshaft together, which makes a difference in performance.
Old Nov 14, 2002 | 07:01 PM
1RMDave's Avatar
Default Re: balancing lsvtec? (VWkila)
so your saying i should do the flywheel ect...?
Old Nov 14, 2002 | 08:06 PM
EFing8's Avatar
hey I sold the flywheel from the b18. well actually bobby has it, i will be getting his b16 one in trade. he got the b18 one lightened.
Old Nov 14, 2002 | 08:26 PM
1RMDave's Avatar
Default Re: balancing lsvtec? (CND_CRX)
thats fine i'm actually just going to use my b16 flywheel, that way i won't have to break in the clutch again. and mr. ying said to use the stock rods with arp bold so i'm going that route instead.
Old Nov 18, 2002 | 12:58 PM
VWkila's Avatar
Yes, if needs be, skip the balancing of rods and go with balancing of the crankshaft/flywheel/pressureplate route.
TeamNextGenChris
Feb 5, 2008 03:46 PM
trecool44
May 20, 2007 07:15 AM
JDMtype Eg6
Nov 21, 2006 06:35 PM
civiceg500
Sep 7, 2004 02:57 PM
eg6style
Mar 28, 2004 12:54 PM
