Balance Shaft removal
I did a quick search and looked at a few threads. It does not seem like Honda guys would do the balance shaft removal.
Why and why not?
From reading, the timing belt goes through it on a Honda. Is that the reason?
The balance shaft is not like a separate thing and can be disconnected on some other brand engines. Correct?
Educate me.
TIA
Why and why not?
Educate me.
TIA
Some Honda guys/techs/mechanics won't remove the balance shaft due to the following reasons:
1. They probably don't know how to...or know the right parts to bypass it after removal.
2. The motor will run a bit rougher because the internal balance shaft is no longer there. Honda did include the mechanisms for a reason,.....to balance the rotation of the engine.
I have seen a buddy of mine removed the balance shaft off his H22 motor and replaced the internals with H23 parts. The automatic timing belt tensioner was removed as well.
Why and why not?
Educate me.
TIA
Why and why not?
Educate me.
TIA
I did not experience any noticeable increase in NVH and the engine actually rev'ed and accelerated a little quicker
so i guess you could say they balance the vibration instead of the rotation. rotation is balanced by the crankshaft counterweights since they both operate at engine speed and not twice engine speed like the vibration.
my guess is Honda included them to appease efficiency-minded buyers looking for ever increasing levels of "refinement" and isolation from mechanicals, noise, discomfort, ect.
