Bad wiring
Old Jan 26, 2007 | 12:21 PM
ubermoc's Avatar
Default Bad wiring
Ok I been having allot of trouble with the wiring and blowing fuses. Anyways I just changed the fuse again. Radio and cig lighter wasn’t working and all lights dim. It works now but when I was changing them there was a wire that just plugged into an unused fuse slot. It was annoying and didn’t seem to be doing much so I removed it. Bad idea.
My car doesn’t start now. Check engine light comes on as it should and turns off after 2 sec. I hear the clicks that need to click and I hear the gas pump on or oil. Don’t remember what makes the flowing sound. But it doesn’t turn over. Everything makes it seem like it will but it doesn’t. So back to that wire. It’s not hot till I turn the key to start the engine. So I connected it back to where I thought it was and nothing. Same problem. I connect it to a hot wire and same thing. Need help. Im missing work because of this and I know it’s something small but I don’t know what it is. I have a pic of the wire.
Old Jan 26, 2007 | 01:01 PM
dustin_crxsi's Avatar
Default Re: Bad wiring (ubermoc)
It looks like a ground wire
havok hybrid's Avatar
check the starter fuse**... Check the single small wire on the starter... Check the fuses UNDER THE HOOD.
Old Jan 27, 2007 | 05:22 AM
ubermoc's Avatar
all checked all right. i pushed it and drove it for about 1 hour and when i turned it off it did the same. and i even changed the battery. i realy think its somthing with that wire.
j0keefe21
Jan 6, 2009 04:05 PM
the_dxB16
Oct 17, 2008 08:06 AM
dennis278
Honda Motorcycles
Sep 12, 2008 04:13 PM
Civic_07
Apr 5, 2008 06:25 PM
