Bad Thermostat??
Old Apr 22, 2004 | 05:25 AM
TGUNNER's Avatar
Default Bad Thermostat??
2000 GSR Started to overheat last night. Bottom radiator hose is COLD. The Thermostat is stuck right?? Could it be anyhting else?? Thanks guys..
Old Apr 22, 2004 | 06:18 AM
spaceman's Avatar
Default Re: Bad Thermostat?? (TGUNNER)
i think if the upper rad hose is cold then your thermostat is closed,is your fan coming on?
Old Apr 22, 2004 | 06:53 AM
TGUNNER's Avatar
Default Re: Bad Thermostat?? (spaceman)
Yes fans are comming on. What else can it be. Water pump?
Old Apr 22, 2004 | 07:34 AM
spaceman's Avatar
maybe is it leaking or making wierd sounds?..do you have any leaks?i would change the thermostat since its not expensive..is there air in the cooling system?if yes then get it out
dbailey
11
Jan 30, 2020 04:27 AM
SurfLifeAway
Jan 20, 2009 02:35 PM
yz125rider21
11
Aug 9, 2006 04:42 PM
Jmunk
Oct 19, 2004 02:51 PM
