Back up operation problem: HELP,PLEASE!
Old Oct 11, 2003 | 08:48 AM
moysaystor's Avatar
Default Back up operation problem: HELP,PLEASE!
I changed my '91 civic to OBD 1. All is good except the CHECK ENGINE LIGHT STAYS ON while I jump the connector for the timing, and I installed the OBD 1 jumper connector and everything else.
The reason i need to correct this problem is because i need to see how it will effect my CA. emission testing . The Chilton manual says to replace the ECU. I was wondering has anyone fixed this problem with out changing the ECU, or is there any thing i can do to correct this problem , or even some advice for what to do?
mikej94civex
15
Jan 6, 2010 02:46 PM
element73
Transmission & Drivetrain
Feb 27, 2009 06:11 AM
bub113
Dec 19, 2008 09:27 AM
