b20vtec turbo... no vtec?
Old Nov 14, 2004 | 02:14 PM
hybridpatient95's Avatar
Default b20vtec turbo... how can i make vtec hit harder?
now the vtec works the vafc shows that it engages. we had lots of problems before this and during the turbo install. what id like to know is their any type of way to increase oil pressure make vtec hit harder. i was thinking maybe a screw on the oil pump or somewhere else?? need answer !! please help!
Modified by kinkbmx159 at 3:55 PM 11/20/2004
Modified by kinkbmx159 at 4:03 PM 11/20/2004
Old Nov 14, 2004 | 02:25 PM
hOndafienD 04's Avatar
Old Nov 14, 2004 | 02:31 PM
k24a4kid's Avatar
I'm a Jackass
Default Re: (hOndafienD 04)
help please !!!!!!!!
Old Nov 14, 2004 | 02:36 PM
oh my goodness....por favor senor
dumpeDc2's Avatar
I'm a Jackass
Default Re: (b20turbohatchback)
mabey a little plug to reduce the oil flow to the turbo or a smaller oil filter. but best thing for you to do is to just check the oil preshure at the vtec solinoid and see if it up to par.
Old Nov 14, 2004 | 02:56 PM
what should the pressure be?
Old Nov 14, 2004 | 02:57 PM
so using a smaller oil filter will increase pressure a little? is this safe?
Old Nov 14, 2004 | 03:37 PM
bump for an anwser
Old Nov 14, 2004 | 03:45 PM
mmuller's Avatar
Mad Scientist
where are you running the line from? the stock oil press. sensor?
If so, run a bigger line from the oil press. sensor to an oil distribution block and go from there
Old Nov 14, 2004 | 03:49 PM
we got the vtec and turbo running off the oil pressure sensor...i thinkthats the porblem...wheres the oil dist block located?
Old Nov 14, 2004 | 04:03 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">we got the vtec and turbo running off the oil pressure sensor...i thinkthats the porblem...wheres the oil dist block located?</TD></TR></TABLE>
there is none, you have to put one in.
something like this:
but you can get a thicker feed line and nicer distribution block from here:
http://www.mcmaster.com/
Old Nov 14, 2004 | 04:05 PM
Default Re: (mmuller)
can we get some directions?
Old Nov 14, 2004 | 04:09 PM
Default Re: (kinkbmx159)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kinkbmx159 &raquo;</TD></TR><TR><TD CLASS="quote">can we get some directions? </TD></TR></TABLE>
yes if youcould dat would begreat dear!
Old Nov 14, 2004 | 05:36 PM
dumpeDc2's Avatar
I'm a Jackass
get a RSX filter it is smaller and fits fine also the way you have it set up sounds like it could be a problem.
Old Nov 14, 2004 | 05:52 PM
thanx! makes it a little easier...will it increase pressure tho?
Old Nov 14, 2004 | 09:56 PM
mmuller's Avatar
Mad Scientist
you can get everything you need from the website above.
1/8 bspt to npt adapter. part# 4092K11 (thats stainless, but you can get brass)
braided hose (page 205)
distribution block (page 162-163)
Old Nov 14, 2004 | 10:03 PM
drdisco69's Avatar
Default Re: (dumpeDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumpeDc2 &raquo;</TD></TR><TR><TD CLASS="quote">get a RSX filter it is smaller</TD></TR></TABLE>
This statement is misleading. The RSX uses the same filter as most of the other hondas, there's nothing special about it. It's smaller than the old style, and the legend and nsx filters, but it's the standard size of the current filters honda sells.
Old Nov 15, 2004 | 07:00 AM
Default Re: (drdisco69)
does any one have any other ideas on how we can fix this problem. need asap!
Old Nov 15, 2004 | 07:45 AM
mmuller's Avatar
Mad Scientist
Default Re: b20vtec turbo... no vtec? (kinkbmx159)
have you checked vtec oil pressure?
Old Nov 15, 2004 | 09:27 AM
no we have been in skool all day...will check it around 3 pm...eastern time.
Old Nov 15, 2004 | 11:41 AM
k24a4kid's Avatar
I'm a Jackass
somebody has to have an easy fix for this
Old Nov 15, 2004 | 12:08 PM
rsx oil filter is smaller in diameter....b-series filter is a 2808 champ # and sx and k-series is 2867....the filter is smaller in diameter, but the gasket is in the same location....i guess we will be trying this tonight.
Old Nov 15, 2004 | 03:09 PM
mattssi's Avatar
where is vtec currently set to engage at? if you bump it up a few hunderd rpms then maybe you will have the necessary oil pressure for the solinoid to activate?
Old Nov 15, 2004 | 03:45 PM
set at 5400....we messed with it and nothing...we tried higher, lower, nothing worked..
Old Nov 15, 2004 | 06:33 PM
mmuller's Avatar
Mad Scientist
soo. all this talking and still no vtec pressure
