b20vtec questions
Old Jan 28, 2007 | 01:05 AM
splickitysplat's Avatar
Default b20vtec questions
i was wondering if i could use gsr eagle connecting rods for my b20 block? if not do i need ls/b20 connecting rods? also does anyone know if i NEED to resleeve the block for b20vtec or could i just get a block guard.
Old Jan 28, 2007 | 05:02 AM
Runnerdown's Avatar
Default Re: b20vtec questions (splickitysplat)
gsr rods are not going to work with the b20 crank, match the rods to the crank you are using. I run stock sleeves with no block guard, this is because the engine is immediately tuned properly. And keep the water temperature in check, running these hot will damage the cylinders.
civicR99
Sep 14, 2004 01:05 PM
pootie.teng
14
Aug 25, 2004 04:50 PM
Slick GS-R
Mar 30, 2004 08:03 PM
Spoon Si
Dec 17, 2003 06:50 AM
