b20b no coolant temp sensor??
Old Jul 20, 2010 | 11:01 AM
fv8s's Avatar
Default b20b no coolant temp sensor??
my b20b does not have any sensors on the thermostat housing. should i tap the housing for a temp sensor or do i need another waterpipe/ t stat housing??
all help is appreciated
Old Jul 20, 2010 | 06:16 PM
MOTION_80's Avatar
Default Re: b20b no coolant temp sensor??
on the thermostat housing is the fan switch contact. if you don't have this sensor, your radiator fan will not start and your engine will over heat.
so, yes you will have to found a thermostat housing with the sensor hole.
Old Jul 23, 2010 | 06:37 AM
RenownPer4mance's Avatar
You will be ok tapping the housing also.
Old Jul 23, 2010 | 07:05 AM
fv8s's Avatar
ok.. so what housing/ neck will i need to my fan kicks??
Old Jul 23, 2010 | 07:39 AM
kyden's Avatar
you'll just need a b series thermostat cover.
Old Jul 23, 2010 | 07:47 AM
If you're just going to replace the neck, it must be from an obd1 b series. The obd0 b series engines have the fan switch in the back of the block. Check the b20b maybe it's back there. It would be a 2 prong sensor near the oil filter. Maybe someone converted it to run the obd0 switch before you bought it.
Old Jul 23, 2010 | 09:06 AM
fv8s's Avatar
the ONLY sensor i have is an oil pressire sensor (i believe). its the one with the nipple sticking out and the part on the harness looks like a hershey kiss. thats the best way i can describe it. after looking at my friends b16 i realized he has a sensor on his thermo housing
Old Jul 23, 2010 | 10:26 AM
Someone probably took it. Where'd you get the engine?
Old Jul 23, 2010 | 11:15 AM
fv8s's Avatar
i bought the engine from a machine shop in North Dakota who installed the Block Guard and bored/ honed and i assembled the rotating system. im not sure who got their hands on it before, but i am going to my garage now so ill snap a pic of what the back of the block looks like. its actually a JDM B20b if that helps??
Old Jul 23, 2010 | 11:19 AM
fv8s's Avatar
scratch what i said... there are two sensors. the one i previously described and a green one with two prongs on the upper half of the block. im guessing that is the fan switch? and if it is will i need the sensor on the t- stat housing now?
Old Jul 24, 2010 | 01:29 PM
bigD's Avatar
just run your wiring to the back of the block
Old Jul 24, 2010 | 10:46 PM
fv8s's Avatar
ok cool
Old Jul 25, 2010 | 07:18 AM
Yep. It doesn't matter which of the 2 wires goes where either so just hook it up however.
Old Jul 29, 2010 | 05:12 AM
fv8s's Avatar
ok thanks for the help everyone
Jesse Santana
Jun 27, 2017 08:03 PM
jtrig
May 31, 2011 06:25 PM
Simmerman
12
Sep 18, 2007 07:05 PM
whiterex
Feb 28, 2005 02:57 PM
