B20 block and Ls head (what kinda results)
Old Sep 20, 2004 | 01:31 PM
pane93civhb's Avatar
Default B20 block and Ls head (what kinda results)
was thinking about getting a b20b cant find a b20z here. and throwing a ls head on it with an ls tranny what kind of power output do u think i can get out of that it will be in my 93 cx hatch... if anyone knows or has experience on this let me no.. i no the compression on the ls motor is higher so maybe it will put down more torque and power. also would like to know which would be a better ecu to use.
Old Sep 20, 2004 | 01:36 PM
non-VTEC's Avatar
Default Re: B20 block and Ls head (pane93civhb)
the LS and B20 heads are identical. dont wate your time swapping out the B20 head for a LS head you wont see any diffrence.
Old Sep 20, 2004 | 01:47 PM
Default Re: B20 block and Ls head (non-VTEC)
so how is the compression lower on the b20 and i thought that the head is where that would be changed at.
Old Sep 20, 2004 | 02:01 PM
PyroProblem's Avatar
B20 Pistons are lower compression.Heads are the same.
Old Sep 20, 2004 | 02:03 PM
Default Re: B20 block and Ls head (PyroProblem)
so if i swap the heads i should swap the pistons too then or what would that help could i use a rod from the b20 if i broke a rod on the ls block i have now.
Old Sep 20, 2004 | 02:25 PM
---seanny---'s Avatar
Use a B20 block and put on a B16B or if you are crazy enough, use a B18C5 head off the DC2R! There's around roaming the streets of New Zealand, and those things are fast. I know of one that has 160kw @ the wheels
Old Sep 20, 2004 | 03:47 PM
Default Re: B20 block and Ls head (---seanny---)
only problem is imnot in new zealand. im in new mexico and we dont have any civic type r's here at all. sorry and hardly any normal type r's and all the ones that are here are sick and clean.. thanks for the suggestion. im just trying to get a right now gain. trying to figure out would it be better to just get annother b18b block or the b20 block and which one will have my car moving faster thanks.
Old Sep 21, 2004 | 03:50 PM
bump before i go home.
Old Sep 21, 2004 | 05:23 PM
Propulsion's Avatar
get a b16 head or gsr head.
Remove B20 head, swap on LS head, now you have a B20 again...
Old Sep 21, 2004 | 07:27 PM
opkjoblacsh's Avatar
Default Re: B20 block and Ls head (SilverCIVIC96)
b20 block b16c head is what i think the perfect combination the b16c out flows the b18c1 and b18c5 (which come stock port and polished) so therefor more airflow more torque and hp
but the ls head is not vtec which is the same head at the stock b20
Old Sep 21, 2004 | 08:01 PM
tinkerbell's Avatar
Default Re: B20 block and Ls head (opkjoblacsh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opkjoblacsh &raquo;</TD></TR><TR><TD CLASS="quote">b20 block b16c head is what i think the perfect combination the b16c out flows the b18c1 and b18c5 (which come stock port and polished) so therefor more airflow more torque and hp
but the ls head is not vtec which is the same head at the stock b20 </TD></TR></TABLE>
gotta get me one of those b16c's!!!
Old Sep 21, 2004 | 10:43 PM
boostn420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pane93civhb &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the suggestion. im just trying to get a right now gain. trying to figure out would it be better to just get annother b18b block or the b20 block and which one will have my car moving faster thanks. </TD></TR></TABLE>
The b20 has more toque, it should be the better engine. A b20b with lower compression may not be faster but I think its worth it in the end because its a stronger engine.
Old Sep 22, 2004 | 08:08 AM
Default Re: B20 block and Ls head (boostn420)
i can see it being a bigger engine but i dont trust cats on ebay to buy a b16 head for the ls vtec and im not sure how to run the oil lines either on that swap. i really dont want to blow another engine.
Old Sep 24, 2004 | 07:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tinkerbell &raquo;</TD></TR><TR><TD CLASS="quote">
gotta get me one of those b16c's!!!</TD></TR></TABLE>
imeant b16a sorry my bad
Old Sep 24, 2004 | 12:08 PM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ---seanny--- &raquo;</TD></TR><TR><TD CLASS="quote">Use a B20 block and put on a B16B or if you are crazy enough, use a B18C5 head off the DC2R! There's around roaming the streets of New Zealand, and those things are fast. I know of one that has 160kw @ the wheels </TD></TR></TABLE>
For anyone wondering, 160KW = 214.6HP
Damills
Mar 10, 2009 11:32 AM
SCIVIC94
Mar 3, 2005 06:57 PM
bryanb2
Jan 18, 2005 07:39 PM
ridestrt
Oct 12, 2003 06:33 PM
